Mis\
Old May 24, 2002 | 09:28 AM
PL95's Avatar
PL95
Default Mis\
I have noticed a missfire on my 95 Lt1. I changed the plugs and it still persists. Last night we finally had a nice night, so i took it for a ride to see if it continued on a dry day. It was worse. Also, a "SYS" code started to flash where the milage normally is. Today i found plug wire 5 has rubbed through the coating to the wire. Would this be the problem or does the "Sys" mean somthing else? Anyhelp would be appreciated. thanks in advance.
Old May 24, 2002 | 10:17 AM
ittlfly's Avatar
ittlfly
Default Re: Mis\ (PL95)
Obviously, you need to replace the plug wire. If it was shorting out, it would have caused the engine to miss (run rough). The "sys" light has probably set a code(s). You need to pull the code to see what the ECM is trying to tell you. :yesnod:
