C4 Trailer tie-down hooks
Old Jun 12, 2012 | 03:28 PM
TravisD's Avatar
TravisD
Default C4 Trailer tie-down hooks
I'm picking up an open trailer soon, and need to get tie-downs for it. So far my research has indicated that T-hooks are the right thing -- this is was the Towing Guide on awdirect.com says, and is considered the normal "GM" style. But... doing some more searches here I've seen a couple of references that T-hooks aren't ideal for a C4.
What are you guys using in real life? If it makes any difference, the car is a '96, and at factory spec ride height.
Old Jun 12, 2012 | 04:25 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I used regular hook style tie down through the factory holes on the frame.
Old Jun 12, 2012 | 07:12 PM
RichS's Avatar
RichS
From an old post of mine:
I loaded mine tonight and took some pics. Doing it this way I compress the suspention and the car does not bounce, shift or budge.
Old Jun 12, 2012 | 09:34 PM
NASCAR314's Avatar
NASCAR314
I do like "Rich S" above me, hooks on the ends of the tie-downs, except I use axle straps on the FRONT as well, I wrap them around the front of the lower control arms, and hook the strap to that. Minimal chassis bounce at that location. I hook the other end to "D"-rings mounted on the trailer.
Crossing the straps in back is important.
I have many "D"-rings on my trailer so I can haul other cars / equipment. Make it versatile!
A "wheel stop" at the front is useful if you have a clutch car.
To C4 Trailer tie-down hooks
