-=jeff=- helped me out the other night diagnosing my bogging problems. 1 of my injectors is on the way out. I would like to purchase some high perf injectors becaus even though my car is stock, I'm looking eventually building out the bottom end and putting on an s/c. I will in a couple months put on the S/C and run 6 psi.
What type and how many lbs. I need your input. '92 LT-1.
p.s. -=Jeff=- is going to help me burn the computer to compensate so that's not an issue+I won't have to worry about an FMU w/ the s/c
On a side note, should I upgrade my fuel pump right away too?
If youre going to replace them now, id just go #24, but if youre planning on getting the SC i would go bigger. Only problem is that bigger injectors may not run right until you put the SC on.
As long as you set the injector constant properly in your ECM, you should be fine. They just won't get the "workout" they will be when the SC is on :cool:
