Anyone using a Crank Trigger?
Old Jun 13, 2012 | 07:30 AM
LD85's Avatar
LD85
Default Anyone using a Crank Trigger?
Anyone using a Crank Trigger for sequential cylinder control?
I am in the throws of making this change in order to have better individual cylinder control, and as a result, get some more HP as well.
I know some use the Dual Sync distributor instead, but I would prefer the Crank Trigger method for my FAST XFI
Old Jun 13, 2012 | 08:12 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Old Jun 14, 2012 | 01:23 PM
LD85's Avatar
LD85
Spoke to FAST tech and my local tuner, they say the past Dual Sync issues have been rectified a couple of years ago, so apparently the dual sync is the the simplest way to go
Old Jun 14, 2012 | 11:53 PM
thetoy's Avatar
thetoy
I am using a crank trigger with the old fast dfi system on my stroker motor. It works great.
Old Jun 15, 2012 | 12:57 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I think "RedLS1GTO" has a crank trigger on his engine. Might want to contact him.
Old Jun 15, 2012 | 05:53 PM
bogor's Avatar
bogor
Made my own crank trigger for my L98 stroker with a sequential Autronic DFI system. Using a Honeywell GT101 sensor (hall type). I put four mild steel teeths equally spaced on the stock crank pulley. The GT101 sensor mounted on a L-shaped aluminum profile bolted to an existing threaded bolt hole on the block. works great.
Old Jun 16, 2012 | 08:51 AM
LD85's Avatar
LD85
Sweet, I'm going buy the FAST because its plug n play,, evidently, I can alter my MSD distributor by removing 7 of the reluctor tabs (?) so I only get one signal per revolution, so I will give that a try...
or,,,, I might pick up a new distributor and sell my MSD 8366
What distributor are you guys using?
Old Jun 16, 2012 | 02:17 PM
bogor's Avatar
bogor
OEM HEI but gutted. I used
a fork style hall sensor under the rotor to give the required one pulse per revolution.
Old Jun 16, 2012 | 02:34 PM
LD85's Avatar
LD85
Excellent, I'm sorry to bug you, but do you have a link to the parts, or can i get them from Jegs or Summit?
Old Jun 16, 2012 | 03:07 PM
bogor's Avatar
bogor
An old pic of the L-profile that holds the crank sensor
Its a standard Honeywell product but this is the only info I found: http://www.haltech.com/store/index.p...ct-sensor.html
The crank pulley with the four teeths I have added
The modified HEI distributor
Needed to remove everything inside to put the bottom from a oil can holder ($1) and grinded a small "window" in it to trigger the Hall sensor.
Here is the hall sensor I used (got it from somewhere else but it gives you some details about the sensor): http://octopart.com/2av54-honeywell-910593
I think I spent about $50 in total (about $45 for the two sensors) and surprisingly enough, it has worked flawlessly. Quite stable spark advance (guess around +- 1 degree) and no issues with interference. Depends ultimately on how you manage to make everything tight and rigid with small clearences and tolerances.
Download the manual to my Autronic system and you will get some good info how to do the crank trigger design with the GT101: http://www.mrm-racing.se/forum/showthread.php?t=294
Old Jun 16, 2012 | 10:49 PM
LD85's Avatar
LD85
Thank you, I understand what I need to do now!
Old Jun 17, 2012 | 04:52 AM
red L98's Avatar
red L98
I'm using a crank trigger with MSD 84697 Pro-Billet Distributor and I love it ...
Old Jun 17, 2012 | 08:19 AM
LD85's Avatar
LD85
I've been checking this out, but can I ask, what is the cap OD?
I need for it to fit behind the Holley Stealth Ram.
Old Jun 17, 2012 | 10:08 AM
red L98's Avatar
red L98
It uses a ford style cap , so it's wide .. but you can clear MSD 8489 with no problem .
http://www.msdignition.com/Products/...stributor.aspx
Old Jun 17, 2012 | 01:49 PM
LD85's Avatar
LD85
Thanks a ton, I thnk I'll pick this up but I don't like the bronze gears.
I can sell my MSD 8366 pretty easily
Old Jun 17, 2012 | 02:49 PM
red L98's Avatar
red L98
Most solid rollers need a bronze gear , But you can just swap out the gears off of the MSD 8366 before you sell it if you want ..
Old Jun 17, 2012 | 05:49 PM
LD85's Avatar
LD85
Phasing the crank and cam seems tricky, is it that tough to do? Sounds like you align the crank with the max timing you would have in the ECU and then set the distributor reluctor to #1 on the cam.
I''m sure I'll figure it out once I have all the parts in my hands
To Anyone using a Crank Trigger?
