Iam talking about the loop from the bracket to the TB. yours is straight my is loop.
how can I fix this. I allready ajudt to the max
sorry. I got lost with TV cable. My brain heard "throttle".. seems as if your TC cable is simply loose.
anyway, mine has been removed a couple times, never had to adjust it.
***edit, my confusion
####add I assume you adjusted it per the FSM or Haynes? it does appear to be kinked, loose, stretched.
Reason: add ####
The TV cable should be tight and straight. There is a spring in the transmission that pulls on it. It is important that this be adjusted correctly because it controls the line pressure in the transmission. The clutches can slip and burn if it is loose. This is what mine looks like:
You adjust it (refer to the following picture) by pushing in on the D shaped button (right hand thumb) and pushing the plastic cable housing toward the rear of the car (away from the throttle body -- left hand thumb & finger). It will click several times when you do this. Let go of the D button and rotate the throttle as far open as it will go (WOT -- Wide Open Throttle). It will click several times as the cable is pulled out of the mount on the bracket.
question when open TB to max do i keep pushing the D shape botton . and before close Tb depress D shape botton
No.
I just adjusted mine. It's easy, like was stated. Push the button and make sure the TB is fully closed. You may have to push on the adjuster to the rear(towards the firewall) for the TV cable itself. I had to on mine because it was a little stuck. (WD-40 fixed that.) Release the button and rotate the TB FULLY OPEN. I did mine slowly and counted the "clicks" the adjuster made. I then did the adjustment 2 more times and counted the "clicks" again to ensure it was the same. (Might be overkill but I was trying to learn as well so I wanted to make SURE.)
... ok I figured it out. I feel dumb now. ... but I am not getting any kind "clicking sound" out of it when I push in the piece and than open the WOT blades to full open though.
