160 Tstat
Old May 24, 2002 | 04:39 PM
vvv90's Avatar
vvv90
Default 160 Tstat
What kind (part #'s please)
Place to buy one too?
Thanks.
Old May 24, 2002 | 04:43 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: 160 Tstat (vvv90)
All I know is they are different fro a typical SBC.. I think a friend of mine got his throught Lingenfelter
http://store.lingenfelter.com/lingen...=23&pf%5Fid=98
Old May 24, 2002 | 04:48 PM
vvv90's Avatar
vvv90
Default Re: 160 Tstat (-=Jeff=-)
awe, I hate when they do that! Did you see the listing for years in the drop down menu. LT1 93-97 ????? I've never seen a '97 C4 before?
I'm sure it should work ;)
Old May 24, 2002 | 04:54 PM
-=Jeff=-'s Avatar
-=Jeff=-
yeah but the F-body got the LT1 from 93-97 which I bet is what they are referring to. Yes it still should work
Old May 24, 2002 | 05:38 PM
Davman's Avatar
Davman
Navigator
TPIS has one for $15.99 and they specify the correct models.
Old May 24, 2002 | 05:59 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
I am changing my thermastat as I write, The housing is to hot and I am taking a break, I went to a parts store and bought a 180 over the counter. I think a 160 would make the car run to rich w/o any mods to the engine.
Old May 24, 2002 | 06:03 PM
vader86's Avatar
vader86
you can get L98s at AutoZone, but the LT1's is different from the typical SBC
Old May 25, 2002 | 10:54 AM
jtjerry's Avatar
jtjerry
Default Re: 160 Tstat (vader86)
160 t stat in my vette made only lower fuel economy (about 2-3 MPG) and nothing more!!!!!! :smash:
Eprom must be changed for real benefits from 160t stat.
Jerry
Old May 25, 2002 | 12:31 PM
abigfoot's Avatar
abigfoot
Default Re: 160 Tstat (jtjerry)
All a 160 degree stat does is lengthen the amount of time the motor takes to get to operating temp, which is typically between 190 and 195. It is fine for pulling your car up to the line and racing the quarter, But in everyday driving it won't really help you.
Your much better off doing the fan cooling switch mod.
[Modified by abigfoot, 10:32 AM 5/25/2002]
Old May 25, 2002 | 01:26 PM
LTxDave's Avatar
LTxDave
Default Re: 160 Tstat (abigfoot)
Thats funny....mine with the 180 stat operated about 195-205. Now with the 160 stat, it operates 175-185.
To 160 Tstat
