It won't do much unless your banking into corners pretty good. I'm waiting to spend my money on the X-Brace they are supposed to working on for Coupes.
It won't do much unless your banking into corners pretty good....
That hasn't been my experience, nor the experience of others who have installed it. The front end tracks much better, esp over bumps. Also, the difference with the targa top removed is unbelievable. The cowl shake is gone. Try it, you'll like it.
I love mine. I noticed a big difference on my car albeit a roadster. My car use to feel like a wet noodle. Between the Camber Brace and the beam plates I installed it's a different car.
Got mine installed a week ago, just in time for the Cruise In. I really got to test it out traveling at high speeds on Monteagle. All I can tell you is the car handles MUCH better at any speed. I can tell a drastic difference even at a slow cruise. The car feels more stable and solid. Honestly the best $150 I've spent on the car. :yesnod: :cheers:
365ZUM,
Where did you get you brace installed. I have all ready received mine and right now i am debating whether or not to have it installed or do it while i am doing shocks. How much did it cost? I have heard that the belt needs to come off. Is this true? Thanks for an info offered. :flag
Excluding putting in my MAT relocation kit in tonght (should take around 15 min.)this was the easiest mod I have done.
-Get the front of the car on jackstands,
-take off the nuts to the top of the strut towers(18mm I think)
-pull the bolts out
-insert camber brace
-insert shims(if needed)
-put bolts back in
-put nuts back on
-torque down
-beers
It took me an hour to install this incluing getting the car up and down off of the jackstands.
I did not have to remove my Serp. belt although I've read that on some years it is necessary.
On the LT1/4 you have to remove the surp belt, it's a bit of a struggle getting it back on. The other issue is be careful of the ECT sensor as you thread the camber brace through the chassis. I ripped the sensor's wires and had to splice it back together. A few other forum members reported they did the same thing ;) . Next time I'd remove the ECT sensor's connector before threading the brace through the chassis, then hook it back up right before I did final tightening of the braces's botls/nuts.
BTW, the customer service on this part is great. I made 3 calls to Dave on the night I installed it. He always answered the phone and was really nice about helping me (even on the third phone call at 10:30pm).
chucks88, what are the beam plates and what do they do? Im tired of my car handiling like a wet noodle with the top off.
My *** end use to kick-out to the right on rapid acceleration and deceleration. Now it tracks in a front and back type motion when accelerating/decelerating.
Looking at the pieces in your hand it is hard to justify paying that much. (I think I paid $145) But when I felt the difference in the rear, after installation, It was money well spent. I've seen pictures of a members home made beam plates, I asked him if he felt a difference and got no response. They do however look easy enough to build.
I put these in also myself. It took a while. I had to remove my x-brace(on convertibles) and drop the exhaust from the front y-pipe back.
I added the beam plates at the same time I changed the diff carrier bushing to poly (along with the rear camber rods bushings and rear spring bushing). The rear end is much tigher around corners and over bumpy/rough surfaces esp while turning. Poly bushings, beam plated and a camber brace runs ~$400, the improvement in handling is worth it. Add a new set of sway bars with poly bushings (less than $250) and you can really change the entire nature of your Vette's handling.
that may have been me......not sure. My poor car is still not running or off jackstands, so no info on my homemade ones :cry :( :sad
Sorry for the late reply. The posts above are correct. We had to take off the serpentine belt and it was incredibly hard to get back on and bolted in.
Even though we installed it covered in bubble rap, we managed to scratch it up a good bit. Be careful and take your time- you shouldnt have any problems.
I also have the C4 beam plates mentioned above. Combined with the camber brace, my car tracks straight even throughout a full burnout (no traction). I'm very impressed and have already told Dave to send me the first production of the Xbrace he's working on. :yesnod:
