'90 won't start
Old Jun 20, 2012 | 08:11 PM
edgee's Avatar
edgee
Navigator
Default '90 won't start
I started my 'vette after letting it sit for 3 weeks. The engine light came on and it was idling rough. I drove about 1/2 mile, the light went off and it seemed to run better. I came to a light about 1 mile away and it stalled while waiting. After about 20 minutes it fired right up again. I drove home and it ran great. I turned it off and restarted it without hesitation. I did this a few times just to make sure it wasn't going to happen again. I went out to start it an hour later and nothing.
The plugs, wires, cap, rotor, and the fuel injectors were replaced less than 1000 miles ago. The fuel pump was replaced two years ago. I checked the fuel pressure at the rail just in case, and that was fine. Any ideas?
Old Jun 20, 2012 | 09:59 PM
VetteMed's Avatar
VetteMed
check battery cables for tightness and corrosion?
Old Jun 20, 2012 | 11:30 PM
rodj's Avatar
rodj
What sort of "nothing" ?
No lights , no cranking , no fire up .............?
Old Jun 21, 2012 | 10:06 AM
edgee's Avatar
edgee
Navigator
It cranks but won't start. On the initial crank it almost fires but won't catch. When you let off the key and crank again, it just cranks.
Old Jun 22, 2012 | 05:22 AM
James Holland's Avatar
James Holland
Cruising
same problem i have,
any solutions?
Old Jun 22, 2012 | 07:15 AM
joe paco's Avatar
joe paco
sounds like ICM. module in the distr. no codes? you will need the codes, either learn to do it or have it done, but without the factory manual and codes it is a long, expensive process.
Old Jun 22, 2012 | 04:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Bend a paper clip and jumper the ALDL pins A&B (upper left), turn on ignition (don't start) and cound the SES flashes.
You will see "1 2" flashed three times, followed by each trouble code three times, finally the "1 2" will flash three times.
Come back with the code.
Old Jun 23, 2012 | 12:37 AM
Cliff Harris's Avatar
Cliff Harris
(I just did this in another thread...) Instructions for retrieving codes:
http://corvettephotographs.com/c4vettes/codes.htm
What they mean:
http://forums.corvetteforum.com/1576116036-post35.html
Old Jun 23, 2012 | 07:35 AM
joe paco's Avatar
joe paco
What they mean:
Cliff, you should make that a sticky, or put in tech section. not one mention of aldl or codes in there. it's obvious that new owners will be clueless. also, fsm uses Tech 1, not the jumper wire.
joe
Old Jun 23, 2012 | 04:47 PM
miker2's Avatar
miker2
spray a little ether in the throttle body.if itfires/starts,buy new injectors.
Old Jun 24, 2012 | 11:34 AM
edgee's Avatar
edgee
Navigator
Cliff-
When I jumped A-B, it came up code 15. When I jumped A-G, it came up 4-31, 4-33, 4-35, 4-37.
Old Jun 24, 2012 | 12:23 PM
joe paco's Avatar
joe paco
Cliff-
15 is coolant temp sensor, which will cause over rich condition, behavior about like you describe -if your engine runs rich. coolant sensor is signaling a low temp and ecm adds more fuel.
code 33 is MAP sensor, in the 91.. no 31, 35, 37 codes in 91 ECM, but are in the CCM.
if you were in section 4.0 using a-g, that is ecm. so, I don't know what your 90 codes are.
unplug the map sensor and see the reaction. if it runs ok, the sensor circuit is suspect.
if you cleared the codes, new codes will set, so you have to try it and check codes.
joe
Old Jun 26, 2012 | 05:54 PM
edgee's Avatar
edgee
Navigator
on a whim I decided to see if it would start today. it fired right up. the cooling fans came on immediately. the longer it ran the higher the rpm's got at idle. I turned it off and tried to restart it and all it would do is crank. I have bought a new coolant temperature sensor and will replace the old one. I will keep you posted on what happens next.
Old Jun 29, 2012 | 12:54 PM
edgee's Avatar
edgee
Navigator
Installed a new coolant temp sensor last night. The SES light went out as soon as I hooked up the electrical connection. Car runs fine now, hopefully that was the only issue.
To '90 won't start
