Carbotech Brakes
Old Jun 21, 2012 | 10:27 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default Carbotech Brakes
It’s that time of year to get your corvettes out and start driving, but more importunately you need to be able to stop if you’re on the fence about new brake pads maybe we can help you out. Carbotech Performance Brakes, the world leader in Ceramic friction materials. It was over eight years ago that Carbotech started building brake pads out of Ceramic, Kevlar, and Carbon for street, autocross and racing applications. Carbotech is the only brake pad manufacturer in the world with a complete line of Ceramic compounds for street, autocross, and track use. Carbotech-Ceramic compounds are known for their unsurpassed release & modulation, while maintaining very consistent torque control characteristics. Carbotech brake pads are extremely rotor friendly and contain 100% non-corrosive brake dust, that’s something that has been unmatched by any other brake pad in the industry. Please contact me with questions or to place an order.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Jun 21, 2012 | 12:20 PM
85vet's Avatar
85vet
Cruise-In V Veteran
I use their pads - allow me to hold the car at the line (drag racing) with dual line locks and a 2-step. Before I went with their brakes I would push through the line and lose before I had a chance to do anything.
Old Jun 21, 2012 | 08:25 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I'm currently using EBC yellows, but I'm concerned they aren't going to handle road racing. I've been thinking about running XP-10s and XP-8s (F/R). It's a dedicated track car with J55's, brake cooling ducts, SS pistons, and Ti shims. I'd like to have a full set honestly in case my first track event (July 20th weekend) of the year. I just didn't have a feel good when I was bedding them. I felt like I started to get quite a bit of fade when they got good and hot.
Also, 3170 lbs with driver, 275/40 and 315/35 NT-01s. ABS isn't wired right now, but will be in the near-ish future. Right now I'm in HPDE 3, but I will be getting a provisional hopefully later this year.
Any recommendations Adam?
Old Jun 21, 2012 | 08:54 PM
96GS#007's Avatar
96GS#007
I run XP10s in the front and XP8s in the rear. I have brake cooling in the front. ~3400lbs. I teach for the PCA, BMW, etc at their track days.
Never had an issue with these pads fading. Best pads I've ever used.
Old Jun 21, 2012 | 11:35 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Mostly street miles + street tires and HPDE 1 /autox = XP8 fronts for me.
Adam is spot on about it being non-corrosive. I left dust on the wheels for the entire winter and into June..wiped right off.
No fade on track at my level and tire capability and no issues on the street.
AA+++ would buy again
Old Jun 22, 2012 | 09:34 AM
Carbotech Adam
Supporting Vendor
Get rid of the EBC just joking. seriuos though I would look at maybe the XP12 front and XP10 rear. I need some more input from you as your driving style and what is your HP? PS ditch the shims. http://forums.corvetteforum.com/auto...or-wear-3.html
Old Jun 22, 2012 | 11:45 AM
Black89Z51's Avatar
Black89Z51
My car ('89) is putting out 322 hp and 340 tq to the wheels. I'm also running DBA rotors. I'm shifting at 5800 rpm. As far as driving style, I don't trail brake as it makes the car loose. Otherwise, it's a track-only car and is driven accordingly.
Old Jun 22, 2012 | 12:37 PM
96GS#007's Avatar
96GS#007
You would be fine with the 10s and 8s. I'm over 450hp to the wheels, shift at 6500, and trail brake a lot. I've been asked when I decide to apply the brakes....I count to 3 and brake when I see God
Old Jun 22, 2012 | 02:16 PM
Carbotech Adam
Supporting Vendor
10 & 8 it is my friend. give me a call I will be happy to place an order for you.
Old Jun 23, 2012 | 04:20 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I can be more direct than Adam - Throw the EBC yellow pads away!
When they changed pad compounds I was one of the "lucky" ones to get a full set to test. They never inspired any confidence on the track.
With that said I run XP12/10 combo at 3450 lbs race weight (car driver fuel)
And I even took the stock pads that came on my 2012 v6 Camaro off and put xp8's on all four corners. I now have a commuter car that can STOP.
Old Jun 23, 2012 | 05:20 PM
Black89Z51's Avatar
Black89Z51
Talked to Adam a few minutes ago and ordered 10s/8s pre-bedded for the car. Something tells me I need to hook up the ABS now.
Old Aug 1, 2012 | 10:34 AM
Carbotech Adam
Supporting Vendor
Old Aug 1, 2012 | 10:37 AM
RandomTask's Avatar
RandomTask
^^ Already ordered a set a couple weeks ago, will be getting a new set after I upgrade the brakes
Run carbotechs on all my track cars. Best. Pads. Period.
Old Aug 1, 2012 | 11:53 AM
Black89Z51's Avatar
Black89Z51
I got to bed them into the pads at VIR a couple weeks ago. Man they grip nice. I was really starting to push them when my PS pressure hose ruptured and sprayed on my headers. I couldn't find another one, so I had to retire for the weekend.
Going to Summit Point Aug. 18-19 so I'm hoping to really see what they can do.
Old Aug 1, 2012 | 06:17 PM
Carbotech Adam
Supporting Vendor
I am just looking for feed back. Sorry to hear about the issues. If I can help with anything let me know. Ideal with alot of forum vendors.
Old Aug 20, 2012 | 12:32 PM
Black89Z51's Avatar
Black89Z51
After this weekend, all I can say is WOW.
I was going really deep into T1 at Summit Point and there was absolutely no hint of fade whatsoever. The brakes grabbed hard and wouldn't let go. I'm sold on these brakes. I had no idea stock J55s could brake like that. I was even-matched with another C4 with bigger brakes. I believe he was running Cobalt pads.
To Carbotech Brakes
