1990 running rough and no start when hot
Thanks Mike
Thanks Mike
joe
** also, if in open loop o2 sensore may be def, code 44 or 45.
** should say CLOSED LOOP, when o2 sensors are determining fuel/air
Last edited by joe paco; Jun 21, 2012 at 08:40 PM. Reason: ** add, correct to CLOSED LOOP
on the aldl, jump terminal A to B, KEY OFF. a -b-c are together at top, 2 empty spaces, then f.
turn key on.
the check engine light, or whatever, will start blinking, count the signals, 1, then 2, followed by 3 seconds, then 12 again.
it will proceed thru the stored codes. count the number of flashes. when it is thru it till do a 12 again.
hell, I don't know if this it right!
been a while since I did a, b. I generally do a-g, to read ccm and ecm at the dash panel speedometer area.try it, if it ain't accurate, someone will correct me, I am sure.
turn off key before using the jumper wire.
