All the plugs are out, valve covers are off, rockers are off.
Now I'm compressing the spring and I can move the compressor w/the spring up and down a bit on the valve but how do I get that SOB off? I'm supposed to remove valve spring cap key but don't know how. Also, I'm should be carefull with the keepers but can't even see them.
well, the valve is moving up and down a bit before it bottoms out on the rope in the cylinder.
Still cant finger out how to remove the spring. Any ideas?
Part of my problem was the spring wasn't compressed enough. What I though was some C clip was the keeper (?).
Now with the keepers off, I can't get the spring over the valve steem without forcing it. There appears to be a o ring that is keeping me from lifting the valve spring off.
Do I just force it up and over? I took a pick of what I'm talking about http://www.zracer.com/images/valvesping.jpg
I don't have experience with those type of seals, but from what I gather in magazines is that is also part of the seals.
It is an o-ring that goes on after the retainer is installed...so I would remove the oring before pulling the retainer. Hopefully you have new ones to replace them with.
The unbrella seal fits over the stem OK but its very loose around the head. I expected it to fully seat on the cone looking thing where the valve goes into. :confused:
Is that expected?
Sorry, I was pulled away from computer...but I don't think I can help anymore as I've always switched to PC seals that are different than the umbrella....:(
If it is just a plain rubber/neoprene umbrella with no metal, it is supposed to be "loose" on the OD of the valve guide. It is called an umbrella seal for a reason. DO reinstall new "O" rings, also. Good luck.
The valve seals should fit tight. I just replaced mine last week. I filled the cyclinder with air, Then used a spring compressor. I did not replace the O ring seals. They are not needed. I had to tap the retainers with a hammer to free them. Then I compressed the spring, Remove the keepers, Release the tension of the spring, Tap the spring from the head, Broke off the O ring seal - The O ring seal was hard and came off in pieces and reverse process to install. I had a problem with the spring compressor making contact with the intake runners. Car runs great now.
If the umbrella fits loose, It will not adjust to fit. You should have to apply pressure to slide the umbrellas over the head. You are defeating the purpose by installing an unbrella that is loose. The oil will get by the seals.
Agreed. Don't waste your time if the seals do not go on tight.
I like using the rubber seals that have the spring metal band around the bottom to hold onto the valve guide. Get rid of the plastic o-rings. I also recommend you replace the valve springs with a set of better than stock replacements ( Pioneer 'Z' springs are the common generic better than stock pressure replacements that work very well and cost very little ). You can get springs for around $35-$40 a set that will breathe new life and smoothness into a high mileage L98.
I can't stress it enough...if the motor has enough miles to wear out stock valve guide seals...the springs are shot as well, and you will likely not be able to get the valves adjusted very well when your done unless you put new ones in.
The unbrella fit loose around the boss. Apperintly that is by design and only special ground heads will fit the unbrella snug. The seal fit real nice and tight over the valve stem. It was just the bottom I was worried about but its not a big deal. I saw a few posts indicating I should use both unbrella seals and O rings. I just did unbrellas and that was it. No more oil smoke, runs STRONG.
Althougt the bolts that hold the rockers werent all that tight :cry (can you say re-do)
Its all done and she runs great! I didn't know what I was doing which made a 1/2 day job into a full day but had lots of help from guys at chevytalk.com forum. Save my **** $300 bucks! BTW, this was on a 74 1/2 ton ;)
The Viton seals are the more positive seals as referenced above- cost about double, gets rid of the umbrella seals.... the rubber o-rings are what get hard and leak, not the umbrella seals. Don't worry about ropes or air compressors; if you bring the piston up to TDC, there isn't any room for the valve to drop down- it's move about an 1/8th of an inch, still plenty of room to work on the seals.
Even with the piston at TDC, I still needed the rope. The keepers were stuck on the shaft and needed a nice beating with a socket and the rope helped soften the impact on the valve.
Also, too much play and I couln't get the keepers out as the valve would fall down too far.
