1994 c4 CLUTCH?
Old Jun 25, 2012 | 05:37 PM
braveheart3158's Avatar
braveheart3158
Default 1994 c4 CLUTCH?
94 48K miles. Brought to Vette Docter on Long island for oild leak. Turns out to be the rear main seal. While apart i was told my clutch should be replaced. Not sure why. Have had the car 3mnths but clutch seemed fine. No slipping, shifted high pedal. Just had a small noise on first shift after start up. Said it was a shaft bearing that he changed while changing the rear main engine seal. I have been searching this site and googled for clutches. There is a organic clutch I found that is manufactured by ZOOM. Is this the best after market clutch to get? I found it on the Summit Racing site. As soon as I figure out how to post an image or video of the car in repair,I will post.
Old Jun 25, 2012 | 06:40 PM
cadmaniac's Avatar
cadmaniac
I'd call Carolina clutch, and speak to them. with that low mileage, and if you drive it easy, you might just throw a disc in it. That'll get you by till the Dual Mass flywheel needs replacing.
I would be curious about the shaft bearing he is talking about. That's a transmission that is usually left to experts to repair. I'm sure he's reputable but I never heard that one before. Maybe he meant the Throwout Bearing... That rides on the transmission shaft. I am a curious person, a mechanics nightmare...
Old Jun 26, 2012 | 05:01 PM
braveheart3158
Default tHANKS
Thanks Cad....Throw in a disc? What kind of disc. Anyway I had called Carolina Clutch. They won't say who the manufacturer of the clutch is anyway. I mentioned Zoom and he said Zoom does not manufacture the Clutch kit. ... I suspect it is the same clutch from either Summit Racing or from Carolina Clutch. The Carolina one was $45 more but I ordered from them anyway. I think I have seen Carolina mentioned on this site before, you recomended them, and they had it in stock. I should get it in 2 days.. Carolina suggested changing thefly wheel if there is any play....I told himn that based on what I have read on this site about the conversions etc.. I will take my chances......I asked Vette Doctor bout why I needed the clutch. He said he would put the old one back in if I want but since we have it apart and paying for the labor I may as well put in the new one. He said he will show me the wear on the clutch, so I can see for myself. Not that I know what to look for. Maybe I should keep the old one just in case there is any problems with the new one? Thanks for the reply..
To 1994 c4 CLUTCH?
