C4 1991 L98 AC Problem
Old Jun 26, 2012 | 08:46 PM
jlroush's Avatar
jlroush
1st Gear
Default C4 1991 L98 AC Problem
2nd owner. AC fuse on door panel must be removed and reinstalled almost every time I turn on the AC. Sometimes it quits after driving or restarting the car. Sometimes it sounds like a trap door popping. Was this a recall or how do I fix this?
Old Jun 27, 2012 | 12:38 PM
leesvet's Avatar
leesvet
your elect a/c has onboard diagnostics. Follow the flow charts for diagnostics. BCM, blend door actuator or some kind of shorted harness. The FSM will guide you thru the steps.
Old Jun 27, 2012 | 09:20 PM
SunCr's Avatar
SunCr
A/C fuse usually just powers the compressor clutch coil and I don't know of any relation to the controls or processor which are on a different circuit (for good reason). If it's making noise and popping there's probably a compressor issue, or maybe it is the Processor Circuit - what's the amperage? 25 amps is pretty much just the compressor.
To C4 1991 L98 AC Problem
