Only one horn works!
Old Jun 27, 2012 | 08:52 PM
Silent Thunder's Avatar
Silent Thunder
Default Only one horn works!
So I want to buy a new horn to replace the one that is not working. My passenger side horn is silent. Does anyone know if that is the high or low horn? The F horn or what??
Old Jun 28, 2012 | 12:31 AM
Speedjester's Avatar
Speedjester
Well if your sure it's the horn.. Remove it.. Then remove the small adjustment screw on the back of the horn and spray some PB blaster in there... Let it sit for a few minutes then bang the horn around hard for a few minutes...then replace he screw and plug it back in...
Worked for me..
Old Jun 28, 2012 | 01:17 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I don't know which horn that one is but if it is the "A" note horn I have a brand new AC Delco replacement horn you can have for $10. plus shipping. In fact, I have two or them, both"A" note so if anyone else needs one they can have it for the same price.
Old Jun 30, 2012 | 11:40 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Jun 30, 2012 | 12:02 PM
c4cruiser's Avatar
c4cruiser
Head to your local junkyard and find a pair of horns from a early 70's Caddy, Buick Electra, or Olds 98. These horns are much louder than the wimpy horns the factory installed in the later years. Try to get the horns as a pair from one car or if you have to search around a number of cars, get horns that are mounted on opposite sides of the car to make sure you get the different notes.
These older horns mount the same way with a single bolt, they have the same single wire connector, and the C4 relay will provide enough current.
Old Jun 30, 2012 | 02:35 PM
markKlein's Avatar
markKlein
Remove the one that isn't working, the letter is stamped on the horns.
Old Jun 30, 2012 | 09:53 PM
Silent Thunder
I will take it. PM sent.
Old Jun 30, 2012 | 11:48 PM
Midnight 85
pm answered.
To Only one horn works!
