Below normal temp
Old Jun 30, 2012 | 09:00 AM
gunnerjuju's Avatar
gunnerjuju
Default Below normal temp
Good morning friends, normally people post here about their coolant temp being too high and how that worries them. Well mine is the exact opposite.
Drove the car to work yesterday and had the low coolant light on briefly, did a quick check and found it to have sufficient coolant. But noticed that instead of it normal running temp of 193-200 it was running 183-190. Staying mostly in the 184 range. In traffic it would climb up as it normally does etc. I guess my main question is what would cause it to run cooler than it normally does? AC blows cold & heat blows hot. I added about 2 quarts of coolant into the overflow when I got home to be on safe side. 89 auto with no mods
Old Jun 30, 2012 | 11:57 AM
wobbles111's Avatar
wobbles111
Maybe the fan switch is stuck on. Wrong or no thermostat?
Old Jun 30, 2012 | 12:02 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Fill and burp the radiator. You may have to repeat the service after the car sits overnite.
Then take it for a drive.
Old Jun 30, 2012 | 02:22 PM
SunCr's Avatar
SunCr
Coolant loss on any '89 should have you looking at #7 for symptoms of a leaking head gasket.
Scan for Coolant Temp Signal/Temp to see how it compares to the Display.
Thermostat needs coolant - not air - for it to work right so recheck once you've got a complete fill and no air in it.
Old Jul 2, 2012 | 03:23 AM
Cliff Harris's Avatar
Cliff Harris
I suggest a new radiator cap. It controls the flow of coolant in and out of the coolant overflow tank and can cause a low coolant light if it's bad (happened to me).
Old Jul 2, 2012 | 09:09 PM
gunnerjuju's Avatar
gunnerjuju
going to try to burp it to make sure no air is in system then see how it runs. I replaced rad cap last year but that doesn't mean it hasn't gone bad. I also suspect that the thermostat might be stuck slightly opened even though heater blows hot (just a guess).
Old Jul 4, 2012 | 06:50 PM
gunnerjuju's Avatar
gunnerjuju
Thermostat was stuck opened. Replaced but first drilled 2 tiny holes on the replacement thermo. Didn't have to burp it. Took the opportunity to clean TB
Old Jul 5, 2012 | 09:46 PM
gunnerjuju's Avatar
gunnerjuju
seabright, you're explanation about the function of the thermo is absolutely correct (according to my research) & logical but I can't explain why now it runs at normal temp after I've replaced the thermostat. if the sensor was bad it would still show low temp. If it was due to lack of coolant then it would overheat. When it was stuck open, the car would get above 210 in traffic but once I was cruising it would go as low as 175 but once I changed the therm it now hangs around its normal 190-200 range. I'm perplexed but pleased that it is back to normal.
Old Jul 5, 2012 | 10:17 PM
desertmike1's Avatar
desertmike1
Your Thermostat will Modulate when it's cool outside, and open more often as the outside temperature increase's. Eventually if it's warm enough outside the Stat will remain wide open...now you rely on the radiator/fans to keep the temps in reason.
Mine stuck in the winter one time, and I could not get above 150f and my heater Suffered greatly.
To Below normal temp
