No start 1986
Old Jul 4, 2012 | 04:21 PM
abdo's Avatar
abdo
2016 C1 of Year Finalist
Default No start 1986
Went to a 4th of July parade today with my '86 Coupe. On the way home I stopped at a friend's place for a few minutes. Turned the key - no start, not even a click. All the lights worked. Borrowed a socket wrench from the friend and took off the negative terminal. Rubbed the surfaces a little with my fingers and put it back on. Turned the key and it started just fine.
This Spring, I cleaned both terminals good. I am puzzled as to why corrosion could form so quickly after only two months.
I posted this just so you can check this if you have a no start condition for no apparent reason.
Old Jul 4, 2012 | 05:55 PM
joe paco's Avatar
joe paco
did that the first time my 91 didn't click. it was the key, didn't read for unknown reasons. it resets in 4 mins, so by the time I unhooked terminal, it was ready.
next time look for a steady SECURITY light when you turn key to run. if you have it, remove key and wait for 4 mins. unless you noticed obvious corrosion. my terminals were clean.
Old Jul 4, 2012 | 06:21 PM
abdo's Avatar
abdo
Some years ago when I had trouble with the ignition not reading the code on the key, I installed a bypass to eliminate the problem. I tend to think it was still a battery connection corrosion problem. I had waited well over 4 minutes after trying to start it today.
Old Jul 5, 2012 | 01:18 AM
Cliff Harris's Avatar
Cliff Harris
The early VATS system does not have a connection to the security light. Later GM moved the VATS function from a separate module to inside the ECM and those are the ones that tell you there is a VATS problem by lighting the security light.
Old Jul 5, 2012 | 04:04 AM
rodj's Avatar
rodj
Originally Posted by Cliff Harris
Later GM moved the VATS function from a separate module to inside the ECM .
Later models ('90+ ) have the VATS incorporated in the CCM ; not the ECM.
All the ECM /PCM ever has is a fuel enable signal requirement from VATS in order for it to fire the injectors
Old Jul 5, 2012 | 07:38 AM
joe paco's Avatar
joe paco
thanks. this is why I normally stick to the 91 year models when I get involved. too many differences in years. besides, he has the vats bypass.
I've never experienced where wiping a visably clean terminal solved a problem but is possible. if the connection is made to the solenoid when cranked, but battery weak, lights should dim or go out, relays click, etc.
joe
To No start 1986
