What is this stuff?
Old May 27, 2002 | 03:48 AM
85WHITEZ51's Avatar
85WHITEZ51
Default What is this stuff?
I removed my intake and found this. It is blocked solid with some residue I guess. The big pic shows the texture of the stuff. What is it and how or should I remove it?
Old May 27, 2002 | 04:03 AM
OrangeC4's Avatar
OrangeC4
Default Re: What is this stuff? (85WHITEZ51)
Did it come from the section that is in the top center of the pic? The part that is green? By the way, it kind of looks like a pistachio nut.
Old May 27, 2002 | 04:20 AM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: What is this stuff? (OrangeC4)
Yah it came from the place you are talking about. I was able to chip out that piece I was holding in my hand. It almost looks like it should be a cooling passage.
Old May 27, 2002 | 05:20 AM
opel's Avatar
opel
That is a water passage it should be clear on the head but it does not go anywere the passage on the intake is blocked. On cars with carbs It's open from one head to the other.
Dave
:flag
Old May 27, 2002 | 08:58 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: What is this stuff? (opel)
Yep that is correctomundo!
:cool:
Old May 27, 2002 | 11:17 AM
VetteNoob's Avatar
VetteNoob
:lol: :lol: :lol:
I didnt know you were tearing apart the 85 this weekend. Having fun? Makes me want to rip into mine too just to replace some gaskets.
Old May 27, 2002 | 12:12 PM
scorp508's Avatar
scorp508
The rear ports were blocked off on my '87 with metal on the intake gaskets when I tore her apart. :yesnod: You should be ok.
Old May 27, 2002 | 12:26 PM
John G 92's Avatar
John G 92
Default Re: (scorp508)
the new gaskets should have them with them or built into them I got felpro's on my 87 and they were built right into the gaskets.
Old May 27, 2002 | 12:46 PM
jfb's Avatar
jfb
That is casting material. A wooden form is pressed into sand mixed with an adhesive, the sand takes the form of the wooden form pressed into it and then molten metal is poured into the sand form. What you have is sand and adhesive stuck into your intake casting. The sand gets colored green from the adhesive.
Old May 27, 2002 | 01:13 PM
Corvette0096's Avatar
Corvette0096
It is a pistachio nut. I read about this in hot rod magazine a while back. Make the car run cooler. The shell releases some enzymes that neutralizes the pH in that coolant. neutralize ph = less corrosive..
:lol:
To What is this stuff?
