Test pipe for an 85
Old Jul 8, 2012 | 05:32 PM
rm1sner's Avatar
rm1sner
Default Test pipe for an 85
I've seen a few threads about this but none with any good links and most of them talking about emmisions and how it's illegal. Can someone tell me where to get a test pipe? I live in Oklahoma and we don't have any emissions. Any help is appreciated!
Old Jul 8, 2012 | 06:03 PM
Slow_Lane's Avatar
Slow_Lane
Rock auto sells one. I too am considering one for off road use as my old cats are more than likely shot anyway. I'd be interested in hearing others experiences with this but also not interested in a smog lecture.
Old Jul 8, 2012 | 06:10 PM
c4cruiser's Avatar
c4cruiser
First, your car has 3 catalytic converters. There are two "pre-cats" just below each exhaust manifold; pipe from those becomes a "Y" pipe that attaches to the front of a "main" cat.
The various Corvette accessory catalogs sells a front Y pipe without the pre-cats. You can also buy a true dual exhaust system; it bolts on and replaces the entire exhaust except the mufflers.
Don't ask muffler shops to cut the cats out and replace them with straight pipe. Even though you don't need to have the car tested, it's a violation of Federal law to remove working cats. If a muffler shop gets caught, they can face a 5-figure fine.
You have probably also read that newer cats actually flow very well, you may not see a real increase in power.
One thing you might try is to remove the entire stock exhaust system, pull the plate,s and tow the car to a exhaust shop and tell them you are building a car for "off-road use only". Then they can bend up and install a true dual system add the mufflers of your choice and haul the car back home and put the plates back on.
Old Jul 8, 2012 | 06:14 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
The 85 doesn't have precats
the problem with the 85 is that the cat is welded on from the factory. you have to cut it off to make the test pipe fit. On the 86, 87, the cat is clamped on.
You can go to a corvette wrecking yard, and since they can't sell you a used cat legally, they would cut off the cat rear flange and sell it to you for maybe $10. Then you just go buy the appropriate 18 inches or so of 4" diameter pipe, get the muffler shop to flare one end, enlarge the other end to fit over the Y pipe, and bolt it on in place of the cat.
BUT
I would leave your cat on, and just put a gauge on your pipe in place of the O2 sensor, and read the back pressure.
If it is 1-2 PSI, I would leave it alone.
If higher, just get a new cat from Summit racing that is a direct fit.
You would not believe how stinky and eye watering your car will become without that catalytic converter.
It's there for a reason.
Old Jul 8, 2012 | 10:28 PM
85vet's Avatar
85vet
Cruise-In V Veteran
The 85's cat is bolted on.
pm sent to rm1sner
Old Jul 8, 2012 | 11:35 PM
John A. Marker's Avatar
John A. Marker
Yes the 85 cat is a BOLT in. No welds or clamps. I took my old cat when I replaced it and cut off the end flanges and then built my own test pipe. I added a pipe so I could tie in the air tube that would have gone to the cat.
Pictures;
I used 1/2" compression couplings to join the tube to the new cat.
Or unbolt the fitting and attache it to the "test pipe". The 85 exhaust system is very restrictive. When I bolted in the test pipe and installed under-drive pulleys and took it to the track....I dropped .5 seconds off my usual run time thru the 1/4 mile.
Old Jul 9, 2012 | 12:33 AM
rm1sner's Avatar
rm1sner
Pictures;
I've heard that new exhaust can make a huge difference on the early c4s, I already have headers on it and plan to build it slowly as I have time. My check engine light is on though because of the oxygen sensor...
Old Jul 9, 2012 | 09:56 AM
c4cruiser's Avatar
c4cruiser
Missed the 85 no pre-cats. :bb
If you don't have the O2 sensor installed, Heddman makes a collector reducer that has a O2 sensor bung already welded in. Using that keeps you from having to cut a hole in the collector and welding a bung in place. It may take a little longer for the O2 sensor to heat up, but you can also use a heated sensor; just find a switched power source.
Old Jul 9, 2012 | 02:24 PM
rm1sner's Avatar
rm1sner
Thanks! I'll look into that, I actually have Heddman headers on my car but I just used the reducers that they came with.
Old Jul 10, 2012 | 01:12 AM
John A. Marker
Drill the hole and weld in the bung and your car will run much better!
Old Jul 10, 2012 | 04:44 PM
rm1sner's Avatar
rm1sner
Well seeing how I have 20 summit bucks on their site and the reducer is only 15.95, I think I'll get it for free. Free is always good!
To Test pipe for an 85
