what is this socket wrench?
Old Jul 16, 2012 | 08:24 PM
cadjaw's Avatar
cadjaw
Default what is this socket wrench?
I was just browsing a corvette catalogue. It showed a ratchet with a torx like head? This is a 1985 corvetter which was given to me. I am now wondering if this car has a removeable top? I have so mjany other things going on with this car I haven't had time to do the research. Let me know what you guys/gals think?
cmj
Old Jul 16, 2012 | 08:26 PM
1985 Corvette's Avatar
1985 Corvette
If you like open air driving, congrats, you have a removable mid section via that wrench.
Old Jul 16, 2012 | 09:28 PM
c4cruiser's Avatar
c4cruiser
That ratcheting Torx wrench you saw in the catalog came with all Corvette coupes so you can remove the targa top. It's a T-40 size so you can simply use that size socket (available at Sears, Lowe's or Home Depot) in a 1/4 inch drive ratchet. The Torx head should be at least 2" long.
There are 4 Torx bolts that hold the top in place. Lower the sunvisors and you will see a hole in the plastic windshield trim near the visor arm. There is a bolt in that recess that you need to loosen (it doesn't come out)
Then just above the seat backs in the top plastic trim you will see a Torx bolt. You need to remove these two bolts. Lift the top off by pushing up at the front of the top and pull away from the "halo bar".
If the top has not been off in some time, it may stick to the weatherstripping so lift carefully. If the weatherstripping tears, you will get leaks and that piece can be pricey.
Old Nov 20, 2012 | 11:40 AM
PirateW5's Avatar
PirateW5
Default Silcone Spray
Just a tip once you get the top off I'd spray all the rubber seals with silicone lube just to keep them fresh and prevent them from sticking the next time, also helps prevent future leaks.
I should add that there actually is a storage place for the wrench in the center console. I learned this after getting the car and scrubbing the owners manual wondering what the clip in the center console was for, (the wrench was missing in mine). And really who ever reads the owners manual....lol
Old Nov 20, 2012 | 01:01 PM
Slow_Lane's Avatar
Slow_Lane
This has go to be a joke right?
Old Nov 20, 2012 | 02:59 PM
PirateW5's Avatar
PirateW5
Default I don't joke about car maintenance
I use silicone spray on all my window seals on all my cars. But sometimes I do use 303 Protectant. I work in the aircraft industry and that's what you use on aircraft to keep seals from dry rotting and wearing out pre-maturely.
Here's a link to what I use, in fact I made a lot of money off of WD40 stock over years. Enough to buy a new Corvette, but I prefer to work on the old ones.
http://www.wd40specialist.com/produc...cone-lubricant
Old Nov 20, 2012 | 03:09 PM
lkl2005's Avatar
lkl2005
Since you guys kinda jumped over to the weatherstripping. I like using the armour all wipes on the rubber. Will this hurt anything. My 86 is near perfect.
Old Nov 20, 2012 | 03:31 PM
PirateW5's Avatar
PirateW5
I actually don't like Armour all that much. I work on aircraft and we use 303 protectant on the wing deice boots which are rubber boots on the leading edge of wings. This protects the rubber and extends it's life. It was developed by an engineer at NASA years ago. I'd say IMHO it's the best product out there for weatherstripping. the silicone spray is good stuff as well and I've used on cars and my wet suits for years.
Old Nov 20, 2012 | 07:26 PM
vetteoz's Avatar
vetteoz
And make sure the car is on level ground when you go to re-install the top otherwise you won't get the bolts started or you will strip them trying
Old Nov 21, 2012 | 01:10 AM
Cliff Harris's Avatar
Cliff Harris
If you look inside your center console, you just might find a wrench exactly like the one in the catalog...
Old Nov 21, 2012 | 07:30 AM
dclafleur's Avatar
dclafleur
Actually on a lot of the '85s (I don't know about all of them just the early ones) the wrench is in a holder in the back console area and it's actually just a manual driver with a straight torx head and an angled torx head. I don't know when they actually switched to the ratcheting one and started placing it in the center console. Maybe if I'm feeling saucy later I'll take a picture of mine and post it up.
To what is this socket wrench?
