1996 dic not working
Old Jul 20, 2012 | 06:40 PM
tonycorvettes's Avatar
tonycorvettes
Default 1996 dic not working
question,about removing the dic on a c4 , can you remove the radio bazel and then remove the dic ,im afraid to pull too hard,does it just pull out?after removing the screws?
Old Jul 23, 2012 | 12:10 PM
tonycorvettes
Default anyone?
anyone?
Old Jul 23, 2012 | 12:55 PM
VetteMed's Avatar
VetteMed
To remove the DIC:
Remove shift bezel/surround plate (2 screws at rear edge of it, under carpet in center console compartment, plus one screw under forward cup holder.
SHift **** removal is optional - you can pivot shift bezel 90 degrees after disconnecting hatch release and lighter plugs.
Remove upper center vent - 2 screws.
Remove 3 screws holding in radio/HVAC/DIC surround.
Gently pull aft to disengage clips.
DIC is held in with 2 or 3 screws (7mm head).
Old Jul 23, 2012 | 11:49 PM
tonycorvettes
Default thanks
i pulled on it and it didnt want to come out,
Old Jul 26, 2012 | 01:32 AM
tonycorvettes
Default thanks fixed
problem was there is a small connector 5 pins in back came un pluged and some pins were bent,,thanks ,,three scres to remove it,,,,,
To 1996 dic not working
