antilock light on 87
Old Jul 21, 2012 | 02:23 PM
quinten's Avatar
quinten
Default antilock light on 87
So the other day my Antilock light came on for a few seconds then went off. I didnt think much of it then a few days later it came on and now stays on. I have a scanner for ecm codes and I know i cant use this for abs codes. I have cleaned front wheel sensors (they were dirty) have done rear yet but will. I have checked the fuse marked brakes, checked the ground in the b pillar. I checked all the wires to the wheel sensors and dont see any issues. I know with the older bosch systems its a pain to find abs problems. I found rockauto had some relays and modulator relays so i ordered them incase those are the problems. Any ideas if I am missing something... Yes the brake fluid is filled about 3/4 of the way to max so its not low fluid. Thanks for the help
Old Jul 22, 2012 | 12:18 PM
scorp508's Avatar
scorp508
How are your wheel bearings in general? All it takes is for the sensor and the reluctor wheel to be off by a fraction and hat sucker can come on. There used to be a monster of a GM sensor/tool set to figure out what was wrong with ABS in those days, but none of us are going to have our hands on it.
Old Jul 26, 2012 | 01:22 PM
quinten's Avatar
quinten
Good news it was just the relay. Picked up a used one from vette2vette and lights off.
To antilock light on 87
