HEI Small Cap Distributor
Old Jul 24, 2012 | 01:34 PM
rcajun86's Avatar
rcajun86
Default HEI Small Cap Distributor
I've been having a fit with finding the correct HEI TPI/TBI(small cap distributor) distributor have gotten two different ones and neither had the .491 shaft they each have a smaller shaft and i need the .491 shaft so my composite gear will fit on the shaft since i've running a roller cam. My original big cap distributor has the .491 shaft but i can't seem to find the HEI small cap distributor with the .491 shaft can you shead some light on this subject please.
Thanks guys solved the problem ordered a MSD 8366
Old Jul 24, 2012 | 07:38 PM
Caboboy's Avatar
Caboboy
Don't forget the coil.
Old Jul 24, 2012 | 07:48 PM
LD85's Avatar
LD85
Yep, 8366 is a solution
To HEI Small Cap Distributor
