rear end misaligned
Old Jul 25, 2012 | 08:38 PM
woody1987's Avatar
woody1987
Default rear end misaligned
Today had the car jacked up and working the the exhaust a little. Noticed the inside of the rear tires were wearing more than the outside. other than a rear alignment is there something else i need to be cking for???
Old Jul 25, 2012 | 09:13 PM
383vett's Avatar
383vett
Get a camber gauge and adjust your rear camber.
Old Jul 25, 2012 | 10:18 PM
leesvet's Avatar
leesvet
4 wheel alignment.
This is 4 wheel independent suspension so the rear wheels are actually MORE complicated than the fronts as far as suspension and alignment..
You can set the camber and even some degree of toe..but to make it drive right and NOT slip around like its on ICE when it rains...
Get a 4 wheel thrust angle (center-line of chassis) alignment.
Old Jul 25, 2012 | 10:40 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
http://www.elantragtclub.com/id554.html
To rear end misaligned
