'84 Air Intake Mod - How to help required
I've read a few articles (posts) by others and have tried the double sided tape, baby powder and oil suggestion to mark the radiator shroud, but it didn't work, after many attempts. I thought about measuring, but I'm not comfortable that it will line up properly. I may try some foam tape with some wet paint, but if it compresses my lines may be off, thoughts?
Does anyone have a tip or suggestion to mark the shroud?
Double side taped the entire bottom of the foam piece & made sure that the shroud was real clean -then shut the hood slowly.
Took a couple times, but finally got it to stick to the shroud.
Then I marked it and cut it a little smaller get the same size as the actual hood opening.
Next I took another block of foam that was larger, and cut a hole in it to match the opening and seal the gap.
So this foam piece stays on the top of the shroud when I open the hood.
Hope this helps.
Glen
