Scan Tool Recommendations
Old Jul 26, 2012 | 04:29 PM
George6488's Avatar
George6488
Default Scan Tool Recommendations
I have a 1994.
What is everybody using for a scan tool?
Money is an object.
Old Jul 26, 2012 | 04:48 PM
braeburn22's Avatar
braeburn22
search for "ACTRON" on fleEBAY or try AUTOZONE, you will get a good one for under $100, your other choice is an ALDL USB cable and a laptop with something like tunerpro RT, google aldl usb.
Old Jul 26, 2012 | 08:33 PM
Purple92's Avatar
Purple92
If you just want to read error codes - most people that I know just ground the "G" pin on the ALDL connector, and read the codes that display on the speedo. No scan tool required for the OBD I system.
Some 1994's upgraded to the OBDII connector - but it's still a OBDI system behind it.
There is a good description on Zip Corvette's website (under tech).
If you want to log data - there are several options. You'll need a special cable (try ALDLCable.com) and Special Software (try Datamaster).
Old Jul 26, 2012 | 10:18 PM
SunCr's Avatar
SunCr
Do an app search for your Cell. Seems to be a lot out there for newer (OBD2) with Code Readers free, though you'll need a cable which they hock with the Apps I've seen.
To Scan Tool Recommendations
