C4 85 Headlight Door
Old Jul 26, 2012 | 05:44 PM
C MCGEE's Avatar
C MCGEE
1st Gear
Default C4 85 Headlight Door
Headlight door will go down but will not go up on one side. I fiqured if it was the gear inside, it would not go down either. So I guessed it was the actuator relay that was the problem. Not so. $48 dollars later for a relay from GM same results. This has been probably discussed here many times before but forgive I did not see it. Thanks for any help. God Bless America. Craig
Old Jul 26, 2012 | 06:25 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Mine wasn't gear related.
I had a short in the harness that went around the headlight frame.
