sway bar bushing question
Old May 28, 2002 | 10:44 PM
1MoorTym's Avatar
1MoorTym
Default sway bar bushing question
Just received my new poly front sway bar bushings with the offset hole "to reduce bind on the end links", but without directions on how to install them.
So, anybody know which way do they go in, thinner part towards to the front or thinner part to the rear ???
Old May 28, 2002 | 10:51 PM
Corvette0096's Avatar
Corvette0096
Default Re: sway bar bushing question (1MoorTym)
Energy suspension? Where it bolts to the lower A arm?
Old May 28, 2002 | 11:40 PM
1MoorTym's Avatar
1MoorTym
Default Re: sway bar bushing question (corvette0096)
Yes its an energy suspension piece.
The bushing are the ones that bolt the center of sway bar to the frame. The hole the bar passes through is off-set from center.
Old May 28, 2002 | 11:41 PM
silver & red CE's Avatar
silver & red CE
...So, anybody know which way do they go in, thinner part towards to the front or thinner part to the rear ???
Thinner part with the cut goes towards the front.
Eric
Old May 28, 2002 | 11:42 PM
Corvette0096
Default Re: sway bar bushing question (silver & red CE)
Old May 28, 2002 | 11:44 PM
1MoorTym's Avatar
1MoorTym
Eric
Many thanks :D
To sway bar bushing question
