Intake Siamesing finished
I was just going to do the intake, but since everything was off, I went nuts. The intake is siamesed 1.25 inches, plus a little bit taken off of the runners, I didn't measure, but I'd guess another .25 inches. I took the mating surface between the runner tubes and runner mounting down to smooth the airflow out of the plenum. The surface is perfectly smooth now. I cut the plenum up pretty good. I can't wait to see how she runs. I also deleted the EGR valve, EGR Solenoid and EGR input tube.
I'm in the middle of a tach/oil pressure guage install. I think I've got it figured out so the stock oil pressure guage will work as well as the new one.
Here's a couple of pics of the intake, her, and her stable mates
[Modified by NoWorries, 3:00 AM 5/29/2002]
[Modified by NoWorries, 3:08 AM 5/29/2002]
I have to get intake off again and I'm not sure if I should do siamesing or not.
What should happen with EGR deleting.
BTW, vette looks good.
:cheers:
[Modified by Sliding, 12:27 PM 5/29/2002]
BTW, how do they get the helicopters in the garage?
BTW, how do they get the helicopters in the garage?[/QUOTE]
Haven't you ever seen Airwolf?, they fly 'em in, :lol: it wuold be too much work to put on dollies and roll 'em in.
With the EGR deleting, there will definitely be some retuning involved. As far as I can tell, it comes into play in highway mode to slightly improve fuel economy/emmisions. With it deleted you'll need a retune, which I will be doing hopefully soon. Until then, you have to give the '87 computer quite a bit of time to learn the new fuel curve without a retune. With your newer computer, it would be better/quicker tuning. My car I have to start at 64 mph steady cruising and slowly work my way up to 75 to give the computer time to realize its not getting extra fuel from the exhaust.
I'll let you know the results as soon as I get them.
85_Dave, I didn't do any before testing, other than seat of the pants and realizing my car was suffocating over 3,900 rpms. 65Z01 has done some research in the 1/4 mile, and his short times did suffer minorly, torque will definitely be affected, because you're taking away the very minor supercharging effect of the long-tubes.
We move helicopters into the hangar on a set of wheels, we also have a dolley, but it takes a long time to setup. They're pretty light.
http://www.corvetteforum.net/c5/nowo...echopper.shtml
Hoping to get the runners cut in 2 or 3 weeks, when the rest of my upgrade parts show up.
Just wanted to let you know Im impressed with the work youve done all along with the car.Really impressive.Look forward to the results and hope theyre really good.
Keep us posted on how it all turns out.
About the intake.
HOLY JEESE! This is awesome! The last time I drove the car, was at 1,300 ft, and it screamed down there. The distributor then proceeded to eat the drive gear. So I towed it up North, to the Grand Canyon, 6,400 ft. Then I did all of this intake work.
The car refused to start. I had no spark. After checking everything twice, valve movement through the filler, power to the coil, plug wire plugged in. I condemned the computer. But I decided to pull the coil to see if a connector was plugged in backwards or something. The possitive wire was completely sheared off. So I soldered that up, and it would run, but barely. I had to really advance the timing to do so. It ended up being a tooth off. So I got that all fixed, and it fired up.
The first thing I noticed is hesitation off idle. My timing is at 7 degrees BTDC. I'm not sure whats causing the hesitation. A thought is the surge of air when the blades open. In Aviation, we call it a Compressor stall, and I'm afraid thats what it is. After it gets over that hesitation, it really gets up and goes.
In Phoenix(1300 feet), it would smoke the tires for about twenty feet. Nothing special. I attributed that to it suffocating, and the stall converter getting it out of the power too quick. I nailed it coming out of the airport, easily 70 feet of spin, at 6,400 feet. Its really late because of that coil problem, and there are deer and elk out, so I let off after it finished spinning. I don't think the siamesing helped much over 4,400 rpms though, but below that, look out!
I'll be able to do some more tests tomorrow when I can actually see whats on the side of the road. :smash:
My guages are sweet too, they're not fully installed, but I love how quick they are.
As a final precaustion, although I knew nothing was in there, I stuck a magnet all the way up to the valves to make sure I didn't drop anything in. On the way in, it was smooth, but on the way out of every port, it would get considerably hung up on the lip of the intake manifold.
I've heard several reasons for this, most people agree that it is to quell intake combustion. I'm sure that was a problem with Carb's, but how much of a problem is it with Fuel Injection? If somebody's got a test manifold lying around, might be worth a try. I'm too scared to do it though. ;)
