1991 Corvette Convertable
Old Aug 1, 2012 | 03:18 PM
fnataro's Avatar
fnataro
Default 1991 Corvette Convertable
I started my vet today and it wasn't running write. Popping under the hood. Then shut down. Could not restart, battery was completed dead. Battery only 30 days old. I jumped it and it started and the same problem existed. Could not get any power to move vehicle. Help!!
Old Aug 1, 2012 | 06:04 PM
1986coupe's Avatar
1986coupe
Any codes?
Is the car stock or any mods?
Old Aug 1, 2012 | 06:06 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Sounds like a dead alternator with a bad diode board and a dead battery.
Buy a cheapie volt meter at harbor freight and do some volts checking.
First, disconnect the negative battery post.
2. Then disconnect the battery lead on the alternator, and put the lead in a plastic bag and wrap it with electrical tape.
3. charge the battery, then leave it sit all night connected to the car.
4. next morning, take a battery volt meter reading with the hand held meter. don't touch the key.
If the battery still has 12.85 or so volts, it's good, and the car is good. the problem is the alternator.
If the volts are 10 volts or below, there is a problem in the wiring somewhere.
Do not expect your alternator to charge a dead battery.
GM cheaped out on the corvette alternator, and it can only keep a partly charged battery going.
So if 30 days ago, you ran your alternator to charge your old battery, you just bought a new alternator too.
So let us know
Old Aug 1, 2012 | 06:07 PM
fnataro's Avatar
fnataro
It is completely stock. Only has 16k miles on it.
Old Aug 1, 2012 | 06:16 PM
fnataro's Avatar
fnataro
Thank you I will try that and let u know.
To 1991 Corvette Convertable
