Recommended Fuel Pressure
Old Aug 2, 2012 | 09:17 AM
JAKE-SON's Avatar
JAKE-SON
Default Recommended Fuel Pressure
I have a 1996 LT1, 401 cubic in with 12.5 compression. Have 42lb Lucas injectors and walbro 255/hr fuel pump with aermotive adjustable fuel pressure regulator. Was wondering what is the recommended fuel psi i should adjust it to.
Old Aug 2, 2012 | 10:23 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The OEM fuel pressure is 43.5. This is also most likely the same pressure your injectors are rated at. I would start there.
