C4 Vette owner needs help
Old Aug 2, 2012 | 06:08 PM
Massimo D'Alessandro's Avatar
Default C4 Vette owner needs help
Well first off i am a corvette lover, i have a 78 silver anniversary and a 87 vette. Always loved them but my most recent purchase is a 89 GTA with a 350 TPI. And of course it wont run, i have already replaced all the injectors, TPS, MAF, and a New ECM and Factory stock prom. The car will just crank over and not fire. I have a snap on vantage scanner and a normal scanner, using the vantage i checked for injector pulse and using the normal scanner i checked for codes. There where no codes and the vantage scanner came up showing an injector pulse so i know its not vats. What else can i do i am at my whits end with this thing. And i know its not a vette but its almost the same motor, Please help me!
Old Aug 2, 2012 | 07:02 PM
leesvet's Avatar
leesvet
Have you checked fuel pressure? Spark?
basics first. 40 psi fuel at key on, 38 at idle.
If its like a vette it should run the fuel pump 2 seconds at key ON until it fires and runs to initiate the pump run.
Old Aug 2, 2012 | 07:15 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Well, you have an 87, start swapping parts since they are the same. By the time you figure it out, your 87 will actually be an 89
Old Aug 2, 2012 | 08:25 PM
Ill Check fuel pressure tomorrow i hope it was that simple
Old Aug 2, 2012 | 08:28 PM
I hope it is that easy, the problem is it wont idle, because it wont turn on
To C4 Vette owner needs help
