Horn Relay 84
Old May 29, 2002 | 12:09 PM
jg84's Avatar
jg84
Default Horn Relay 84
Does anyone know where the horn relay would be for a 84? I've lost the horn, fuse seems OK as other pieces working on that circuit. Any advice would be appreciated.
John
Old May 29, 2002 | 01:25 PM
fixvet's Avatar
fixvet
Default Re: Horn Relay 84 (jg84)
On my '88, it's located behind the driver info. panel in the center section of the dash above your radio. I got the part at pepboys. I replaced my relay, but my horn still doesn't sound, but my alarm does. :crazy:
I've got to dig into the steering column next, I guess, to see if the problem is in there. I'm assuming my horns, under the hood, are okay.
Good luck,
Fix
[Modified by fixvet, 9:28 AM 5/29/2002]
Old May 29, 2002 | 01:52 PM
jg84's Avatar
jg84
thanks, did your horn ever work? My did, I mashed it because of a stupid driver and now it stopped working. I took of the horn button on the column and it looks OK, might need to test that switch first.
thanks for the help.
John
To Horn Relay 84
