1993 crankshaft help
Old Aug 14, 2012 | 08:57 PM
93Rubie's Avatar
93Rubie
Originally Posted by chrldo
im not a mechanic. so im a little confused , if its a neutral component can you buy a new damper and bolt it on?
Yes
Old Aug 14, 2012 | 09:43 PM
chrldo's Avatar
chrldo
i checked the factory service manual today, says if damper is replaced,new balance weights of the same size must be installed on the new damper in the same hole locations as the old damper. sounds like its balanced with the crank.
