fx3 suspension dead.........HELP!!!!!!
Old May 29, 2002 | 08:05 PM
vette punk's Avatar
vette punk
Default fx3 suspension dead.........HELP!!!!!!
Suspension light came on,codes 23,31,43;they cannot be cleared,checked per shop manual,leads me to replace the control module which is $1600.00 list price. I would prefer to keep and fix the FX3 system but that is a lot of dough. Anyone have ideas on what could be the problem? Is it common for these modules to fail?
Jim B. :D
Old May 29, 2002 | 08:13 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: fx3 suspension dead.........HELP!!!!!! (vette punk)
Email me at home. I'll get you taken care of.
jeff2577@yahoo.com
Old May 29, 2002 | 08:40 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: fx3 suspension dead.........HELP!!!!!! (Jeffvette)
Share, Jeff, share! :(
Old May 29, 2002 | 08:54 PM
PeteL's Avatar
PeteL
23 is common if you have turned the ignition key to on, but not started - three times in a row.
31 is left front out of position
43 is selective ride switch out of position or open, make sure it is centered.
Make sure control is on a detent, start and drive car for a while. Then reset codes by removing battery negative cable for a minute or so. Sometimes this does not reset FX3 codes so you have to ground terminal A and B on the ALDL in a very exact fashion: Connect A to B for 2 secs, disconnect for 2 secs; do this three times perfectly with 2 secs between and it will reset.
Then tell us the codes you now get.
Pete
Old May 29, 2002 | 10:30 PM
vette punk's Avatar
vette punk
Default Re: fx3 suspension dead.........HELP!!!!!! (PeteL)
Pete,
I tried to clear the codes at the ALDL as described in the shop manual,also tried to disconnect the module and the battery cable,codes still will not clear. Checked power and grounds at the module connector,all look good. The module will flash the 12 code and failure codes but will not clear the codes. I am stumped.
Jim B. :confused:
Old May 29, 2002 | 10:43 PM
PeteL's Avatar
PeteL
One guy last year, it took him many times to get that 2 second timing right to clear the codes from the FX3 controller. I also remember that he could not clear the codes by disconnecting the battery, but not sure this was an early FX3.
If you can't clear and follow the proceedure in the manual to check on each code, it seems the problem is the controller. Replacements are available, on a budget talk with Contemporary Corvette for used. I'd try Jeff Koop to see if new or rebuilt is available. Doug Ripey I'm sure has units available.
Work the service manual carefully and follow the steps and see what happens. Step by step.
Pete
Old Jun 1, 2002 | 09:11 AM
vette punk's Avatar
vette punk
UPDATE: The car is fixed. Thanks to Pete and Jeff for their help. The codes were cleared after several attempts at getting the on/off timing correct when grounding the ALDL. The problem with the left front actuator was a loose shock absorber top nut! The actuator was being pushed out of position by the loose nut. Cost to fix problem....$0.00 excluding time.
Thanks again to all,
Jim B.
:D :D :D :D :D :D :D :D :D :D :D
Old Jun 1, 2002 | 02:50 PM
Drewdog's Avatar
Drewdog
Cruise-In III Veteran
Cruise-In IV Veteran
:cheers:
Old Jun 3, 2002 | 06:08 AM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
The power of the forums. Probably saved yer azz alot of $$$$. Remember that. Bow down to the forum at once!!!!!!!!!! You can pay with your soul. LOL j/k. Good to see feedback like that helped. Pleases me to know some crooked mechanic's kickin himself at a lost opportunity to fill his pockets full of $$$. :jester
Old Jun 3, 2002 | 12:47 PM
Jeffvette's Avatar
Jeffvette
Default Re: fx3 suspension dead.........HELP!!!!!! (MaSTeRofDZaSTeR)
You need to go back and ask them how come you were able to fix it for free?!?!?!?! :confused: :mad
To fx3 suspension dead.........HELP!!!!!!
