From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by Shara
'93 vette. car suddenly accelerated wide open running the rpm's up to 7-8. I stood on the brakes in an attempt to stop. The brakes were very "hard". ...the car would "buck and jerk".
Just a WAG but I'd do a close inspection of the brake booster before spending any money.
There are pics on this board of a cracked booster shell that was only visible from underneath.
The original poster said the car ran fine at the dealer so any huge vaccume leak theories are out the window. Second you need fuel to go along with that air and if the TPS is not reading a higher opening the engine will get no more fuel.
Take the car out, turn the cruse control on and see if it happens again. If it was me I would just turn the ignition off but not all the way so I could still steer and coast to a safe place to park if it's not the cruse.
I have seen this happen, but it was the floor mat that slide forward and pressed the gas pedal. Check your floor mat and make sure it isn't loose. This can also explain why the dealer didn't find anything wrong.
Also, if this happens again just put the car in neutral. That way you keep the power steering/breaks and you have time to safely stop the car.
Very good information, you may have just hit it dead center.
I beg your pardon, my post was the first response and while I didn't get technical as to the exact source of a possible vacuum leak I kept it simple just to get the OP steered in the direction I felt the problem was in.
My apologies, you are correct. I got done reading thru them and forgot yours. My bad.
Sara, if your still reading these replies, I have a question for you. Beings your car is an auto, did it downshift when this happened? If so, then I would say that the throttle body had to have physically opened. This could happen if the cruise control module malfunctions and pulls the throttle open.
just my opinion. a vacum leak will need fule to raise the RMPs like the op stated. the throdle would have to almost have to be pulled or pushed Ir by foot or cruise actuation. lost on a couple of things why did you not just turn the key to off or put the car in nutral. Imlike the floor mat deal the best..
This post got me to thinking and I took my 87 out on the freeway to try out the cruse since I have never used it in this car and it has a BBK throttle body. Guess what the cruse did not seem to work then I forgot about it being on and ten minutes later went up a slight incline and the car shot up to 100 plus before I got the switch turned off on the cruse.
It was not WOT but it was mashed pretty good to go from 80 to 100 before I knew it. I am sure my problem is the heavy spring on the BBK throttle body making the actuator for the cruse to push too hard.
I should swap the throttle body and runners back to stock since the tune is off anyway. There is a big hole in the fuel map at mid throttle, it runs good crusing and wide open but not mid way.
Take the car out, turn the cruse control on and see if it happens again. If it was me I would just turn the ignition off but not all the way so I could still steer and coast to a safe place to park if it's not the cMruse.
It's all speculation at this point. I've witnessed cracked boosters leaking intermittently. And the IAC might dump enough fuel to create the problem. Still worth checking.
A vac leak even with MAP would still need a throttle input to dump that kind of fuel. I don't think the odds are too good to have an intermittant vac leak and scewed tps input at the same time.
