If the antenna does not retract all the way, a little WD-40 goes a long way.
Try that first. Might take a few times, but might start working again!
Unfortunately, you can hear the gears just not meshing when you turn the radio on and off. The place i took it to says they can get an OEM replacement for $260, but I'm not willing to pay that much.
You don't need a new antenna, you need a new mast. I just replaced one on my '89 C4. I used this supplier, these guys are cheap, and stock OEM antenna masts!
