1991 c4 started by itself
Old Aug 9, 2012 | 08:57 PM
cimchazz1's Avatar
cimchazz1
Default 1991 c4 started by itself
Recently picked this car up and had disconnected the battery (negative) to do some work on it, and while I was re-connecting it, I had left the ignition switch in the "on" position and after the power flashed off and on 3 or 4 times, the engine started. I probably shouldn't have left the key in the "on" position, to start with, but I am surprised it started itself. Is this to be expected if left in "on" position?
Old Aug 9, 2012 | 09:34 PM
yedister's Avatar
yedister
Maybe she really liked your touch, you have magic fingers. It should not start until the ignition switch is turned passed the ON position. Check the ignition circuit, could be switch is going bad.
Old Aug 9, 2012 | 10:27 PM
cimchazz1's Avatar
cimchazz1
I'm hoping it had something to do with the old aftermarket remote start system I just (surgically) removed, it was cycling the locks and doing other strange things, and I didn't have the FOB for it.
Old Aug 10, 2012 | 10:27 AM
383vett's Avatar
383vett
Disconnecting and connecting the battery with the ignition switch on could harm the ecm. Voltage could surge to the computer. Your remote starter probably had something to do with the starter turning and the car starting. Potentially dangerous situation.
Old Aug 10, 2012 | 01:52 PM
cimchazz1's Avatar
cimchazz1
Thanks, hope I didn't hurt anything else. That's what happens when I'm working on something half asleep, have no Idea why that ignition was in the on position. I installed the rebuilt alternator last night and it started and seemed to function ok, would that indicate I got lucky this time and didn't fry the ECM? Anyhow, still have a mystery wire coming from the battery negative distribution block that looks like it was connected to another wire hanging near it with a fuse case (fuse was fried inside and stuck). Maybe someone replaced a blown fusible link. I'll have to find a diagram showing what connects to this block so I can trace it back. But I think all these problems were somehow related to the remote start somebody "scabbed" into the under dash wiring.
Old Aug 10, 2012 | 02:13 PM
Calderone's Avatar
Calderone
happened to me many many times, i kick myself everytime
this happens , it's bad for the ecm i have been lucky it's still ok
but you never know !
To 1991 c4 started by itself
