Motor Build
Old Aug 10, 2012 | 02:00 AM
Cellkid's Avatar
Cellkid
Default Motor Build
Can someone point me in the right direction for any publications that would be helpful while attempting to build my first motor. I have done just about everything else except build a motor. Im looking to build a 383 for my 92 as a winter project.
Old Aug 10, 2012 | 03:36 AM
thomasev's Avatar
thomasev
I don´t believe there is a precise answer about this. Sure there are many good books around. I build my own stroker last winter (http://thomas-chevy-c4.blogspot.no/) and I changed direction of the build a few times after reading articles on web and talking to other engine builders. Sure you can read a lot from books/articles - but my best advice is talk to others experience builders and compare answers. My originally plan was to bore/hone my own block (LT1). I ended up buying a short block from US. This build was my first ever and I am very happy I decided to start build on a short block assembled by a experienced workshop in US.
I suppose you have a gen II SBC (LT1). I would recommend converting to a dowel pin driven opti (LT4). There are more options regarding timing chain (like heavy duty timing chain) for the LT4.
Anyway - good luck with your plans/build. My build took many hours (not only hours to build) investigating options and I also ended up with some parts not needed due to lack of experience.
thomas
Old Aug 10, 2012 | 05:18 AM
Calderone's Avatar
Calderone
Get the John Lingenfelter book as well !
Old Aug 10, 2012 | 02:16 PM
Cellkid's Avatar
Cellkid
Thank you for the replies!
Old Aug 10, 2012 | 06:31 PM
Muffin's Avatar
Muffin
This will give you a start:
http://www.cartechbooks.com/
There are several others. Also check your local book stores.
If this is your first build keep it simple, get to know your machine shop folks and listen to what they have to say. You can waste a bunch of bucks if you are not careful.
Old Aug 10, 2012 | 10:55 PM
96GS#007's Avatar
96GS#007
This one is extremely well written with lots of pics. It covers the fundamentals that you need as well as more advanced information. Click on the pic and it takes you to the Summit website. Amazon also sells it.
Old Aug 11, 2012 | 05:19 AM
93 ragtop's Avatar
93 ragtop
it a no nonsense book that goes through all the machine work and gives alot of advise on what to look for.
Also, look at this thread. http://forums.corvetteforum.com/c4-t...-pictures.html
To Motor Build
