Rough idle and hesitation...
Old May 29, 2002 | 10:51 PM
Reverend Nasty's Avatar
Reverend Nasty
Default Rough idle and hesitation...
The car ran fine this morning on my way to work and almost back home this evening when the car began to lose power causing the car to chug. I pulled over and the timing sounded off from the rough lope of the car. Taking it up to 3-4 grand caused the engine to shake as if it was missing a cylinder. Oil pressure, water/oil temp, and gas levels were fine. I let it sit idle for a while and everything went away after roughly 5 minutes. The check engine light came on and the car drove perfectly on the way home. Within the last 5,000 miles the fuel filter, optispark, coil, and coil wire have been replaced when new GM parts. Spark plug wires have not been replaced since I've owned the car (20, 000 miles), but the check engine light leads me to believe that it is an electronic problem other than the plug wires. I plan on taking it to an honest mechanic and would like to know prior what you guys think could be the catalyst of my problem.
Old May 29, 2002 | 10:56 PM
ittlfly's Avatar
ittlfly
Default Re: Rough idle and hesitation... (Reverend Nasty)
It could be several things but rather than taking the SWAG method (scientific wild a-- guess).. pull the codes and see what the ECM is tell you. :yesnod:
Old May 30, 2002 | 12:58 PM
Corvette0096's Avatar
Corvette0096
Default Re: Rough idle and hesitation... (ittlfly)
Old May 30, 2002 | 01:29 PM
vader86's Avatar
vader86
pull the codes
To Rough idle and hesitation...
