1996CE caliper pin
Old Aug 15, 2012 | 11:45 AM
Roy123's Avatar
Roy123
Default 1996CE caliper pin
Clunk when backing up & brakeing .Front caliper pin seems loose allowing caliper to move when brakes are applied in reverse .13" brakes(HD) , pin not available any more?Pics for standard brake pin looks the same , but maybe a different diameter ? Thanks , Roy
Old Aug 15, 2012 | 03:25 PM
aminnich's Avatar
aminnich
Do you have the anti-rattle clips in place?
Old Aug 15, 2012 | 08:25 PM
Roy123's Avatar
Roy123
Default caliper pins
Anti-rattle spring is in-it holds the caliper foward . Going foward is quiet ,no problem . Going backwards the caliper moves back(1/16") pushing against the anti-rattle spring & hits the caliper mounting bracket - makes a clunk ! Seems like the mounting pin is too small a diameter & allows movement .Maybe thats the way it should work with the caliper bracket taking all the force .If no one else has been bothered with this clunk , I guess it's fine . They all do it ,sir.
Old Aug 15, 2012 | 08:49 PM
MissileDoc's Avatar
MissileDoc
Here's the pin you are inquiring about.
http://willcoxcorvette.com/advanced_...ecad1b04b8e63c
Old Aug 16, 2012 | 12:10 AM
Phat98's Avatar
Phat98
The brake pads will groove the caliper pin, causing clearance and slack - I had one fail on my '94, caliper came loose and gouged the inside of the wheel.
O'reillys has them - http://www.oreillyauto.com/site/c/de...1266&ppt=C0064 - does both front calipers. I'm assuming you mean these and not the guide pins, which are available also.
Old Aug 16, 2012 | 09:54 AM
Roy123's Avatar
Roy123
Default pins
New pins , all is well . Thanks , Roy
To 1996CE caliper pin
