coilovers= ride height adjustability?
Old Aug 16, 2012 | 03:30 PM
1996man's Avatar
1996man
Default coilovers= ride height adjustability?
I know some of the more expensive coilover system are dual adjustable and you can change your ride height.
I am curious how much of a difference it would make on ride height between one extreme setting to another.
If one were to have a front fascia that is fairly low like a greenwood kit, I was wondering if you could technically have the ride height set a little higher for street use and then "slam it" so to speak when you went to the track to autocross.
Anybody who owns coilovers care to chime in?
Old Aug 16, 2012 | 03:40 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
It's not a setting like on the shocks. There's a thread on the body, and you put it where you want depending on the springs. Ride height adjusts spring pre-load
Old Aug 16, 2012 | 04:21 PM
1996man's Avatar
1996man
Wow, those are some great pictures!
Looks like you can adjust it quite a bit! It almost looks like its ready to go offroading in that second picture!
Do you have a guestimate of what the difference in ride height would be between the first and second picture? Looks like it could be as much as 3" or so but then again its hard to tell just from pictures.
Beautiful car by the way!
Old Aug 17, 2012 | 12:10 PM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Yeah, you've probably got a good 3" of range for the spring adjustment.
I like riding on the coilovers
Old Aug 17, 2012 | 02:46 PM
BrianCunningham
3in from one extreme to the other in my case.
But it depends on the springs, but also the shocks.
They come with different length shafts and travel on them.
You want them pretty close to the middle of the travel so the bump and rebound are the same.
The other way I adjusted them as different thickness mounts at the top.
As well as offset mounts to the rear uprights, but that was more to clear the rodends
Old Aug 17, 2012 | 02:55 PM
dan_t's Avatar
dan_t
A good coilover will NOT adjust pre-load when adjusting ride height. Maybe not possble with the C4 setup though.
Old Aug 18, 2012 | 11:53 AM
ZO7 JOSH's Avatar
ZO7 JOSH
DRM coilover kit
Old Aug 18, 2012 | 12:15 PM
ZO7 JOSH's Avatar
ZO7 JOSH
http://youtu.be/aoi6sMuDc04 Here is a video right after we installed the kit; had the fronts perfect and hand to adjust the rear after the ride. Once the ride hight was right I would never go back to a leafspring agian.
Old Aug 18, 2012 | 03:23 PM
BrianCunningham
Right, but you need adjustment on both the top and bottom perches, I haven't seen a C4 coilover setup with an adjustable top perch.
Old Aug 18, 2012 | 06:34 PM
1996man's Avatar
1996man
What exactly makes you say this? is it that much more comfortable of a ride than the leaf springs?
is the ability to take corners at higher speed that much more appearant?
Just curious as to what the major difference was that made you never want to go back. There is no wrong answer. Im just trying to learn as much about them as i can
Old Aug 20, 2014 | 03:51 AM
sunnfish's Avatar
sunnfish
I put coil over shocks on my 86 and ride is 110 0/0 better. You ask about cornering I'm not a rode and track guy but it feels great on the street.
Old Aug 20, 2014 | 09:05 PM
cshuman's Avatar
cshuman
Sounds great what cam do u have?
To coilovers= ride height adjustability?
