Battery flashing in DIC. WTH
I am going to check the battery alone.
Any other suggestions, let me know your thoughts.
1993
I had an intermittent problem in my alternator and it was sometimes charging and sometimes not (light came on -- light went out -- light came on). It was interesting because I could see the voltage creeping up as the battery charged and then it would start going down until it got to 11.5 volts and the light would come on. I hit the alternator with a screwdriver handle when it wasn't charging and it started working.
I took the alternator apart and didn't see anything obvious so I put it back together. It has worked fine since then (3 or 4 months). I guess there was a dirty connection in there somewhere.
