How hot will it get ?
Old Aug 21, 2012 | 09:29 AM
JackDidley's Avatar
JackDidley
Being in Texas, I guess the heat is normal for you. Weve set about 10 temp records this summer. In my lifetime weve had a few 101*days and thats it. This year we had about 10 106* days. Normal would be low 90*s.
Old Aug 21, 2012 | 12:16 PM
THE 383 admiral's Avatar
THE 383 admiral
It's the factory settings on your prom.. GM set the fan table temps. To high. Good ole emission robbing years. Pay to re-flash.. If you were close.. I would convert your prom. and flash myself..
Old Aug 21, 2012 | 03:03 PM
jsiddall's Avatar
jsiddall
If your coolant starts boiling then you definitely need to shut it down. GM says to shut off the engine at 260 which is just before the coolant boils. You shouldn't kill your engine if you follow those guidelines though obviously there are some who don't feel comfortable letting their engine get that warm.
Old Aug 21, 2012 | 03:09 PM
JackDidley's Avatar
JackDidley
I do my own chip tuning. Have ever since I switched to E85. I just dont recall what temp I set the fan to come on.
