'91 700R4 TV Cable Question/Shift Issue Still
Old Aug 19, 2012 | 10:03 PM
cimchazz1's Avatar
cimchazz1
Default '91 700R4 TV Cable Question/Shift Issue Still
My '91 I bot recently has a square button (instead of half round) on the TV cable and it doesn't seem to be very tight after I set it, is it possible it is the wrong cable? I bot the car with a shift issue and I'm still trying to see if I can narrow down what the issue is. Pan was relatively clean (usual mud on magnet). I'm going to say it stays in 2nd because I can move the shift lever to 1st and it drops down. It has shifted a few times for me after I have reset the cable, but only for a few minutes.
I think I am getting down to either spending way too much to have someone else (hopefully) fix it , or pulling the valve body and trying to figure out if anything is wrong there. Should I connect a pressure gage 1st and ck pressure?
Old Aug 20, 2012 | 04:24 AM
Cliff Harris's Avatar
Cliff Harris
I have seen TV cables with a rectangular plastic button. I believe those are aftermarket. The one I played with seemed pretty good (the spring was strong, which is the important thing -- it needs to hold the cable housing securely).
Old Aug 20, 2012 | 09:49 AM
mcm95403's Avatar
mcm95403
Here is my thread about this from earlier this year: http://forums.corvetteforum.com/c4-t...djustment.html
Old Aug 20, 2012 | 10:58 AM
cimchazz1's Avatar
cimchazz1
Wow, thanks, that looks EXACTLY like my '91, including the TV (not television) cable, (except for the nice injectors, which I need to replace on mine). But I wasn't so lucky after the adjustment, my trans still seems to start in 2nd and stay there. So I am now assuming somebody changed the TV cable and the fluid and filter awhile ago because there was 1 american thread pan bolt that someone put in and stripped a thread (I have found that whenever someone else has worked on something I have, it's usually screwed up worse than it was to start). But thanks for the info, I am thinking the next step is to drop the pan again and pull the valve body, something I have never done before, but the alternative is hearing some trans shop tell me I need a $1500.00 trans rebuild, I guess, so what do I have to lose, right?? I'm trying not to disturb the exhaust system if possible, though.
Old Aug 20, 2012 | 03:46 PM
mcm95403's Avatar
mcm95403
Where are you located? One of the guys in the NorCal section has a low-miles rebuilt trans for $400.
http://forums.corvetteforum.com/nort...ale-400-a.html
Old Aug 20, 2012 | 06:16 PM
cimchazz1's Avatar
cimchazz1
Thanks, Michigan. Maybe I will attempt to drop the valve body and see if anything looks to be stuck or missing, I get the feeling it's a valve body issue. Of course, I should probably get a good 700R4 service manual 1st, any suggestions on what to look at in the VB besides the TV (not television)?
Old Aug 20, 2012 | 09:29 PM
aj1988's Avatar
aj1988
When I changed out my trans I could not get the tv cable adjusted. Took it to a trans shop and they told me the cable had streched. New cable and it now shifts fine.
Old Aug 21, 2012 | 01:10 PM
mfi's Avatar
mfi
When I had my trans rebuilt for the second time the trans shop could not adjust the cable and wanted to replace the valve body.I brought it to Vette Doctors , they adjusted the cables, had to start from scratch which seems to be the only way, the trans shop was messing around with the the throttle cable only. get it fixed soon or you will trash the tranny for sure...Cost me $100.00...after spending $1000.00 on a rebuild..but I didn't care as it runs great now.
Old Aug 24, 2012 | 11:49 AM
daddog's Avatar
daddog
St. Jude Donor '15
Default sounds like my story
I had 1" of "extra" cable past the throttle lever that I could NOT adjust out with the recommended procedure. after the trans on my '88 had been taken out for seals replacement. I thought stretched cable too, but a brother here on the forum said that the routing of the cable more directly ( as in NOT going around the outside of the dipstick tube but the more logical closer route inside that tube) would have the effect of adding length to the cable (wire core). I took the slack out of the cable at the throttle end by cutting off the extra 1" and putting a new cable terminal at that end. I know it was a "farmer" fix, but it worked!
I think you have to remove exhaust to replace the cable with a new one. What did the shop charge to replace yours? dd
Old Aug 27, 2012 | 10:40 PM
cimchazz1's Avatar
cimchazz1
Wish there was a place like Vette Doctors in the Detroit Metro area, I don't know who I can trust around here , I'd gladly pay 100 bucks to have my trans shifting properly. I usually do my own work, but I have never done auto trans work. Right now I am suspecting there is a problem in the valve body. I'd rather take it to someone who knows what they are doing and won't rip me off, but have no idea who that might be, so I will learn how to do this myself, I guess. Any suggestions on what the best valve body repair kit might be for a '91 700R4 in a daily driver?
Old Aug 27, 2012 | 11:00 PM
Katherinejjm's Avatar
Katherinejjm
Old Oct 7, 2012 | 12:08 PM
cimchazz1's Avatar
cimchazz1
So what did they do, replace the valve body? Did they put a different cable in, too? How did they fix it?
Old Oct 7, 2012 | 11:30 PM
Cliff Harris
The TV cable adjustment should take 30 seconds and you don't need any tools, so there's no reason not to do it.
This is a TV cable bracket for a carburetor, but the picture is so good that I like to use it (the cable itself is the same):
(1) Push in on the D-shaped button with your right thumb (could be a rectangular plastic button if it's an aftermarket cable).
(2) Push the plastic cable housing to the rear (away from the throttle body) -- left forefinger and thumb in the picture.
(3) Release the lock button.
(4) Turn the throttle valve to the maximum open position (WOT). The cable housing will click several times as it comes out of the adjuster. Make sure the throttle is all the way open and the lever hits the stop.
When you're done the steel cable should be straight and tight (NOT saggy like the one in the link posted earlier):
Old Oct 8, 2012 | 12:12 PM
cimchazz1's Avatar
cimchazz1
Thanks, great pics. I have done this over many times and I found out that my trans won't shift out of 1st (or 2nd if it gets that far) unless, after I use the set process you described, I push the button on the adjuster (back in) and pull the cable back out a few clicks to make the inner steel cable even tighter. Problem is, if I go to WOT after that, I pull the cable a few clicks lose my adjustment again. What is that a symptom of? Wrong (aftermarket) cable? Wrong TV spring? I have no idea what anyone has done to this trans, if anything. I only know I have the square button cable, probably aftermarket. Don't know why anyone changed it? So I am looking for the most probable issues to check 1st.
To '91 700R4 TV Cable Question/Shift Issue Still
