Spark advance question
Old May 30, 2002 | 08:09 PM
AS84's Avatar
AS84
Default Spark advance question
What total spark advance should I be running with my setup? Mods in signature. My autoXray tells me my total spark advance is 45 degrees, doesn't this sound a little much? my base timing is set at 10 degrees
[Modified by AS84, 6:09 PM 5/30/2002]
Old May 31, 2002 | 02:40 AM
drive it's Avatar
drive it
Default Re: Spark advance question (AS84)
Well it all depends.....though that does seem like a lot-is that at WOT? Or cruise? If it's at lower loads then it's fine; however if that's at WOT/high loads then I have to ask how much knock retard are you seeing?
