1992 LT-1 no crank
Old Aug 23, 2012 | 01:47 PM
kraven's Avatar
kraven
3rd Gear
Default 1992 LT-1 no crank
my 92 LT-1 wont start about once every 9 months. Push start catches but will not stay running. Let sit for 7 minutes and starts and runs like never an issue! Confused and worried about getting stuck.
Kraven
Old Aug 23, 2012 | 01:58 PM
383vett's Avatar
383vett
Sounds like a bad vats. That's the security system that uses the resistor chip in your key. Sometimes they get tempermental. May be time for a vat eliminator.
Old Aug 23, 2012 | 02:01 PM
leesvet's Avatar
leesvet
Do you know the difference between a VATS event or a engine run problem?
do you mean that it will not turn the starter....or that it will crank but not fire?
If its a VATS event it may stumble and fire IF you push the car (a manual trans) to bump-start it but it cannot run because VATS has the injectors shut down for at least 4 minutes.
Old Aug 23, 2012 | 02:10 PM
kraven's Avatar
kraven
3rd Gear
i do not know what VATS or engine code is.
car does not crank- battery strong lights windows work
clears up and starts in short time.
Old Aug 26, 2012 | 11:19 PM
chrldo's Avatar
chrldo
vats is your ignition key has a micro chip in it to prevent it from starting if the correct key isnt used. your ignition system reads that chip and will then let it start. do you have additional keys you can try? thats one thought. you could have a bad neutral safety switch if its an automatic or a bad safety switch on the clutch pedal if its a standard transmission.
Old Aug 27, 2012 | 01:28 AM
rodj's Avatar
rodj
Originally Posted by kraven
i do not know what VATS is
Read
http://www.thirdgen.org/vats_passkey_system
Old Aug 27, 2012 | 01:14 PM
kraven's Avatar
kraven
3rd Gear
Default vats
thanks guys- now I know what vats means! Car started up in 6 minutes, so I guess cleared itself. Seems to happen once every 8 or 9 months.
Thanks again
Kraven
Old Aug 27, 2012 | 04:43 PM
chrldo's Avatar
chrldo
take it to a good locksmith that does cars and have the keyswitch replaced. its going to fail and probably at the wrong time. doing it now might be cheaper than a long distance flatbed tow!
To 1992 LT-1 no crank
