Master cyl swap
Old Aug 23, 2012 | 03:05 PM
leesvet's Avatar
leesvet
Default Master cyl swap
On the 87 vette, the master cyl is a single resevoir that is no longer available.
Will a 88 or later duel resevoir master cyl fit the mounts and will the line connect to the 2 res master cyl?
My plastic res is cracked all to s*** and literally falling apart. Filled it with fluid yesterday and today noticed it was wet all around the connector pipe. The thing is cracked and coming apart.
Old Aug 23, 2012 | 04:53 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Rockauto.com has the single reservoir OE style in stock if you're concerned about retro-fitting something.
Old Aug 23, 2012 | 06:24 PM
leesvet's Avatar
leesvet
Mostly need the cup and the pipe to the 2nd port. After looking at it, I think its like other yrs as far as the master itself, its the cup/resevoir thats odd being a single. Guess I can try to find just the cup...
Old Aug 23, 2012 | 06:41 PM
SunCr's Avatar
SunCr
Don't know why you couldn't swap to newer - it's still a split system, and looking at the NAPA site, that's what they sell for the '87. Always figured that GM went to the 2nd reservoir to ding us on repairs.
Old Aug 23, 2012 | 07:05 PM
leesvet's Avatar
leesvet
Thats what I'm thinking...
I'm not sure if this current master cyl is the original or not...it has 2 ports on top for cups but one is just a fitting to feed from the rear port where the res is located...
So I'm assuming that the only real difference is that the 88+ model masters come with a separate cup for each port instead of the single that tried to feed both. In either case all I need is the resevoir(s)...but I may end up having to replace the whole damn thing. Its shocking to see what time, heat and vibration has done to that plastic cup...the cup itself looks as though it was made of glass and had been dropped from 10 ft...spider web like cracks all thru the thing. The fitting to the pipe..cracked and pieces breaking away. Thats what started leaking.
I made a fuel line hose clamp "band-aid" for the fitting to hold it together until I can find the parts...seems to be holding for now but not for long.
Old Aug 23, 2012 | 08:47 PM
ChasD's Avatar
ChasD
Default Just add the second cup in front
I had the same issue to deal with due to my rear cup leaking on my 1986. The front is just a cap and a tube to connect to rear cup. I called Corvette Central and they said to just add a new cup in front. So, I bought two new reservoirs, two new seals, and one new cap. The parts were very cheap and it works perfectly. I did all new brakes recently...pads, bias spring, ss lines, rotors. I can tell you the front cup is the front brakes, as the fluid level dropped quickly when the new pads wore in. The beauty now is that you won't run low on fluid as quickly when the pads wear. Hope this helps.
Old Aug 23, 2012 | 08:50 PM
ChasD's Avatar
ChasD
Default Fitting new reservoirs
I managed to suction out just enough fluid to do the swap without allowing air in when I did this. It was nice to not have to bleed it at the time. Of course, I had to later when I really did the rest of the brakes and lines.
leesvet's Avatar
leesvet
Corvette central has this?
if so, SOLD !
I'll call them in the next cpl days...Thanks !
Old Aug 24, 2012 | 12:41 AM
Cliff Harris's Avatar
Cliff Harris
I replaced my one cup plus tube setup with the two separate cups because I wanted to be able to tell which brake circuit had a problem.
Old Aug 24, 2012 | 08:36 AM
Chuck Tribolet's Avatar
Chuck Tribolet
You can tell even with the single cup -- there's a divider in the bottom
of the cup.
Chuck
Old Aug 24, 2012 | 09:56 AM
indianavette's Avatar
indianavette
of the cup.
Chuck
Would either of these work on your car? I've got a bunch of single and double cup units, removed from brand-new late '80s C4s being turned into race cars. Been shelved ever since.
Old Aug 24, 2012 | 11:32 AM
leesvet's Avatar
leesvet
Yessir..
PM sent.
Old Aug 24, 2012 | 02:19 PM
Crepitus's Avatar
Crepitus
Now you have my attention...were these manual systems with a ballance bar MC setup? I dont want to hijack this guys thread, we can do a PM or new thread if nessary.
To Master cyl swap
