ABS Question?
Old Aug 23, 2012 | 10:19 PM
Sam Ruger's Avatar
Sam Ruger
Default ABS Question?
I'm thinking I should drive with the ABS on in heavy freeway traffic in case of an emergency stop. The manual seems to indicate it's for wet surfaces. Opinions?
Old Aug 24, 2012 | 12:34 AM
Cliff Harris's Avatar
Cliff Harris
You can turn it off? Not an option on my car...
My ABS got exercised today when I made a fast left turn into my driveway (oncoming traffic) and when I hit the brakes with the front tires in all the dirt and trash along the curb the left front ABS kicked in. I would NEVER be without ABS. It's kept my front end from being crumpled several times over the years.
The only situation I ever heard of when ABS is a liability is driving in snow. Without ABS the tires snow plow and build up a pile of snow in front of them that helps stop the car.
Old Aug 24, 2012 | 03:54 AM
Ricky 91 vette's Avatar
Ricky 91 vette
, its really important to have it working, if u brake hard in a curve without it u will drift just like me when my abs wasnt working!!
Old Aug 24, 2012 | 07:49 AM
1986coupe's Avatar
1986coupe
I live in an area that gets tons of snow every year. I have never heard of snow building up in front of a tire to help it stop. ABS is great in snow and ice. When ABS kicks in it helps to keep the vehicle going in the correct direction...if the wheels lock up in snow and ice then the vehicle can slide in undetermined directions. Lots of video of that on the internet. Lots of video of Porsches with ABS on the snow and ice.
Old Aug 24, 2012 | 08:52 AM
leesvet's Avatar
leesvet
ABS is NOT an option to use as needed.
Its working
or
its defective.
I'd truely HATE to be sitting in a courtroom facing criminal charges (vehicular manslaughter) for tampering with motor vehicle safety equipment when you rear end somebody and the investigation finds that YOU disabled the ABS....tampered with the brake system...
Don;t drop the soap.
Traction Control is a different story. THAT is optional.
Old Sep 2, 2012 | 03:27 PM
Sam Ruger's Avatar
Sam Ruger
Well! Put me down as the south end of a northbound horse. I was looking at the ASR switch and saw the squiggley line under it and had read elsewhere it had to do with rainy conditions (The ASR button is not listed in the OM index except for location) and ASSuMEd it activated the ABS if you were on wet pavement. That's when I wondered why you wouldn't just have it on all the time? Duh!
Old Sep 2, 2012 | 07:31 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
As mentioned, you can't turn ABS off (Antilock Brakes).
As you have discovered, you have a button to turn ASR off though.
ASR is your "traction control".
By default, ARS is on. If you push the button, you will (should) have a light come indicating that ASR is off.
And unless your a very experienced driver (used to driving a lightweight rear wheel drive car), I highly recommend you don't turn that off for normal everyday driving.
Go out to a flat open parking lot and "play" with it if want though.
You need to get a feel for how your car drives when the rear tires break lose.
It is very easy to spin out and it happens so fast, that unless you have experience with it you will end up against a curb or in the ditch.
Old Sep 2, 2012 | 09:11 PM
93Rubie's Avatar
93Rubie
Wanna learn how to drive, turn the ASR off, now go find a auto-x, then do it in the rain. You learn throttle control, steering inputs,etc...really quick. I've only ever spun my car once in auto-x and it was dry out. Too much throttle and it was no surprise when it went around, the car warned me. I could feel it start to break away, I just said, screw it and kept my foot planted.
Old Sep 2, 2012 | 09:12 PM
Aardwolf's Avatar
Aardwolf
I believe it's in gravel you wouldn't want ABS so the pile builds up in front of the tire.
In general ABS is a crutch for poor driving (avoiding a panic stop is tough!). I think it depends on the advancement of the system these days though. The system on my year was pretty bad. When the tire skids you lose braking traction making your stopping distance longer. If you can learn to modulate braking near lock up without skidding, you will stop in less distance.
Old Sep 3, 2012 | 04:10 AM
Ricky 91 vette
It's easy for u to say that, I know that too, and I was driving cars with no abs for over 15 years, and I can make the car comes in complete stop using less distance than any other car with advanced braking using what u r describing ( modulate braking near lock up) , but when we talk about panic stop, as it happened to me couple times so far (even though I consider my self very good driver) a panic need to stop the car may happen to any driver no matter how good he is or how much alert he is and no matter how much attention he pays to the road, driving safely doesn't depends on u only, it also depends on the others who are sharing the road with u, and there are times u will just be thinking that u need to stop the car in the same moment to avoid a big accedent, and no matter how much u train ur self on modulating the braking u will not have enough time to do that and u will just have enough time to slamm ur foot on the brake peddle putting all ur weight on it!!! AND THAT'S WHEN YOU WILL THANK GOD FOR HAVING A WORKING ABS IN YOUR CAR !!!!!
To ABS Question?
