Front Drag Shocks
Old Aug 25, 2012 | 08:36 AM
C409's Avatar
C409
Default Front Drag Shocks
....... Whose drag shocks are you racers using ? ... Seems there are none actually listed for C4 vettes ......... I found a Competition Engineering adjustable that I think will fit ........ But I just wanted to touch base with those of you who have experience with shocks that not only fit but work as well ! ............ Thanks , Bob .....................
Old Aug 25, 2012 | 01:35 PM
383vett's Avatar
383vett
I've been running the same Competition Engineering shocks set on 90/10 for the past number of years. I ran them on the street and now with them strip only. I can't remember the length, just measure the travel of your original shocks. I think I used the ones for a 70's Camaro.
Old Aug 25, 2012 | 04:44 PM
red L98's Avatar
red L98
Yup same here , they worked better than the coil overs i upgraded to .. So i put them back on and sold the coilovers
Old Aug 25, 2012 | 05:26 PM
Calderone's Avatar
Calderone
how they perform on the street ?
do they help a lot on traction ? thanks
im interested , any links ?
Old Aug 25, 2012 | 05:56 PM
85vet's Avatar
85vet
Cruise-In V Veteran
QA1 Double adjustables infront
Old Aug 26, 2012 | 01:27 PM
383vett's Avatar
383vett
A drag shock is not going to give you great handling on the street. I used to remove the shock and return them to the 50/50 setting between races, but with the stiff springs of an 84, it didn't make that much difference and I just left them on the 90/10 setting. They help transfer weight to the rear at the track along with disconnecting the front sway bar. Ran like that on the street too and it was fine. Just don't try an autocross.
Old Oct 8, 2012 | 03:52 AM
Calderone's Avatar
Calderone
thank you !
any of you guys remember the part #
did a search for our years and nothing came on their site
Old Oct 8, 2012 | 07:42 AM
rodj's Avatar
rodj
RC3014P was the single adjustable race (Stocker Star "R" Series ) shock for a late C4
QA1 have changed their part #
Have to check my paperwork but IIRC 10" -15" travel so # TR502 would be current replacement;stud / T bar mount
IIRC early cars were lower ( 9" - 14" ?) so # TR505 would be correct for them?
http://www.qa1.net/qa1_motorsports/d.../r-series.html
Edit
Have #TR511 listed as single adjustable front for C4's
#TD511 as double adjustable front
http://www.qa1.net/qa1_motorsports/d...djustable.html
C409's Avatar
C409
thank you !
............. I am using Comp Engineering # C2610 ........ FYI ... in case it matters ... these are non gas filled shocks and I lost about 1/2" of front end height ... setting the adjusters will test your strength and your patience ...........
Old Oct 8, 2012 | 08:58 AM
Calderone's Avatar
Calderone
i like Competition Engineering's prices !
I hope this is not an example of "You get what you paid" here
1/2" lower would be cool ! Is adjusting them a hard task ?
Thanks guys !
C2610 front only ? what about rear ?
Old Oct 8, 2012 | 10:28 AM
cv67's Avatar
cv67
St. Jude Donor '05
you can loosen the A arms slightly to help the front end get unbound too.
I wouldnt leave it like that on the street though.
Used to run 90/10s way back on another car. Drove fine but panic stops on skinnies will make you religious. Never drove it in the rain
They work though
Old Oct 8, 2012 | 10:30 AM
Calderone's Avatar
Calderone
i have never drove the car on skinnies , do you lose too much brake power ?
Old Oct 8, 2012 | 10:49 AM
383vett's Avatar
383vett
You lock them up once, and it's time for a new set of skinnies. The Mickey Thompsons that I use come with about 3/32 of tread. There is a reason the aren't DOT approved.
Old Oct 8, 2012 | 10:51 AM
Calderone's Avatar
Calderone
even with abs ?
To Front Drag Shocks
