LT4 guys, what do you trap at?
Old May 31, 2002 | 01:03 PM
scorp508's Avatar
scorp508
Default LT4 guys, what do you trap at?
Title says it for the most part. What are most of your stock trap speeds?
Old May 31, 2002 | 01:15 PM
FoolCrzy's Avatar
FoolCrzy
Default Re: LT4 guys, what do you trap at? (scorp508)
Before the HotCam, The previous owner did a 13.166 @ 106.39MPH..
I can't wait for headers and exhaust... :yesnod:
[Modified by FoolCrzy, 12:16 PM 5/31/2002]
Old May 31, 2002 | 01:24 PM
LT4POWR's Avatar
LT4POWR
In the 105-107 mph range. Probably depending on shift points and weather conditions.
Old May 31, 2002 | 01:38 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Default Re: LT4 guys, what do you trap at? (LT4POWR)
13.6 but I'm a lousy driver....
Old May 31, 2002 | 01:46 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
My trap speed when stock at the Texas Motorplex in Ennis was 108 mph. Air temperature was a little on the chilly side--in the 60's. Lets not talk about the ET. Cold track + worn GS-EMT = Lots of wheel spin & loosy 60 ft times.
Old May 31, 2002 | 01:48 PM
scorp508's Avatar
scorp508
Thanks guys. I'm trying to get an idea of what my car is making before we tackle the loose ends and start getting it tuned. Knowing the LT4 is a 350hp engine, that gives me a very good idea. :cheers:
Old May 31, 2002 | 02:22 PM
Arisa's Avatar
Arisa
Default Re: (scorp508)
my best to date......
13.2 @ 111.05 with a 2.294 60' time Yuk !
And yes I have the slip if you think I'm wacked ! That was in stock form. None of the below listed stuff.
[Modified by Arisa, 1:25 PM 5/31/2002]
Old May 31, 2002 | 03:10 PM
scorp508's Avatar
scorp508
I completely believe you. My MPH always tend to be higher when I spin also.
Old May 31, 2002 | 03:28 PM
365ZUM's Avatar
365ZUM
109mph with a terrible run and a small 210/224 cam.
Old May 31, 2002 | 03:30 PM
scorp508's Avatar
scorp508
Is that the stock cam?
Old May 31, 2002 | 04:40 PM
luvmy92's Avatar
luvmy92
I believe that is after MORE Performance got done with it, as I have the same 210/224 Cam in mine...
Edit: I think ConeKiller managed 109 mph on his stock (maybe K&N/exhaust) LT-4.
Mike
[Modified by luvmy92, 2:42 PM 5/31/2002]
Old May 31, 2002 | 05:55 PM
RichS's Avatar
RichS
Default Re: (luvmy92)
I think stock I was around 106-108. But now it's a bit faster :D
Old May 31, 2002 | 07:03 PM
GS Ragtop's Avatar
GS Ragtop
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
Mine stays between 106-108 too. Never did get the GSC launch down pat, so the 60 ft times suck. Engine is totally stock - only bolt-ons are an open lid and Corsa exhaust.
Brad
[Modified by GS Ragtop, 6:04 PM 5/31/2002]
Old May 31, 2002 | 08:14 PM
ericcer's Avatar
ericcer
Default Re: LT4 guys, what do you trap at? (GS Ragtop)
13.060 @ 106.48 mph @73 degrees. 1.94 60' with really no wheelspin.
Old Jun 1, 2002 | 02:14 PM
zelement's Avatar
zelement
Default Re: (Arisa)
stock, 108-109 mph with my GS.
Old Jun 1, 2002 | 03:40 PM
365ZUM's Avatar
365ZUM
[QUOTE]109mph with a terrible run and a small 210/224 cam.
Yep, that's the one. It's an exceptional cam for someone who is looking for a completely stock idle and decent power. After the new cam, I dynoed at Breathless during the CF Cruise IN last weekend at 342rwhp/378 rwtq! I'm impressed. So impressed, that I wish I had gone with a bigger cam! :(
There is absolutely NO noticeable lope at all with the 210/224.
Oh, and I ran the car at the 1/8 strip last night. My trap speed was 88.7 MPH with ALOT of wheel spin. Anyone know if that's respectable??
[Modified by 365ZUM, 2:44 PM 6/1/2002]
Old Jun 1, 2002 | 03:57 PM
Red94Vette's Avatar
Red94Vette
Im an LT1 guy but I trapped 105.46 last night
93% humidity
78 F
29.92 in Hg
2.193 60'
13.47 1/4
105.46 MPH
To LT4 guys, what do you trap at?
Old Jun 1, 2002 | 04:32 PM
Patrick96LT4's Avatar
Patrick96LT4
Default Re: LT4 guys, what do you trap at? (Red94Vette)
Scorp,
110 is my highest strap speed stock. with a ton of 109's. My 12.7x times were with a 106-108 trap speed, and my 12.9x's had a 107-109 trap speed.
Old Jun 1, 2002 | 04:47 PM
gears's Avatar
gears
My best trap is in my sig.Cant wait to see what it will do when I get it back!
Old Jun 1, 2002 | 07:33 PM
Bruce's Avatar
Bruce
Default Re: LT4 guys, what do you trap at? (gears)
base on your speed trap. I would say your motor now making about 300-315rwhp.
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
Agostino built 383ci
